Go Back   Automotive Forums Car Chat > Isuzu > Trooper | SLX | Bighorn | Wizard
Old 07-12-2005, 08:06 PM
Andrey Andrey is offline
1998 Isuzu Trooper PROBLEM.
I have a problem. On my 98 3.5 with TOD. After driving for about 20-25 minutes (normal city driving) every time i come to the stop, or just when i'm about to stop my front end starts shaking-vibrating really noticablesame when im just about to move. If i shift trans to neutral i have no problem. I hope its not my TRANSMISSION going. Otherwise runs good, good brakes and rotors. What is a problem?
Andrey
Old 07-12-2005, 10:38 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: 1998 Isuzu Trooper PROBLEM.
I would start by checking your tranny fluid level.
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 07-13-2005, 04:56 AM
Level is good I just had it changed, but problem was even before that.
Old 07-13-2005, 10:06 AM
Isuzu Guy
Check to see if your selector on the dash matches up with the one on the floor. Put it is D and then gently push forward to se if the dash one jumps in to N.
See the FAQ's on tranny selector.
-Ryan
Isuzu Moderator
Car Show Tips
Old 07-13-2005, 05:22 PM
Everything is fine. It only starts doing it after about 20-25 minutes driving.
Old 07-22-2005, 10:46 AM
kplusten kplusten is offline
My 99 3.5L Trooper did the same thing. I had the pan removed and it had pieces of metal from a retainer ring failure. I recommend you do not drive it as you have probably already ruined the torque converter and can ruin more internal gears increasing the cost when you get it rebuilt.
