Old 07-12-2005, 07:40 PM
tsipsi20 tsipsi20 is offline
Send a message via AIM to tsipsi20
Good or bad compression?
Hey guys, I have a question regarding my compression test today. Here's the results.
Piston 1: 140psi
Piston 2: 140psi
Piston 3: 155psi
Piston 4: 155psi
I did the test thinking i blew a headgasket. It was blowing white smoke(antifreeze?) out the tail pipe for about 10 minutes as I was driving, then it quit after I let it sit, and hasn't done it since. But these numbers are too high i would think to be a headgasket. My question is the jump between pistons 1,2 and pistons 3,4. Is this a bad thing? 15 psi? And aren't adjacent pistons usually different, instead of the same in this case. The car just rolled over 150,000 on stock internals. Give me some feedback!
1990 Eagle Talon TSI AWD
MOD LIST:
______________________
Mitsubishi s16g, Turboback 2 1/2 in. w/ Hi-Flow Cat, ACT 2600 Clutch, K&N Filter, Taylor 10.5 mm Spark Plug Wires, BPR7ES Plugs, Dejon Tool UICP, Turbo XS Type H BOV, Samborskey Shift Kit, Walbro 255lph, Injector Clinic 550's, 2g mas, Vaccum line elimination, SAFC II, Pocketlogger, 17" Motegi Gloss Black Rims, VIS Carbon Fiber Hood, Eibach Lowering Springs, KYB AGX, Homemade boost controller, Autometer Boost/Air Fuel
Old 07-13-2005, 09:57 AM
No comment... anyone?
MOD LIST:
Old 07-13-2005, 12:40 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: Good or bad compression?
anything below 145 psi is what mitsubishi calls the "service mark" it might be time for a re-build anyways.
95 Talon TSI AWD
97 Eclipse GST
Old 07-13-2005, 01:35 PM
Are you kidding? That compression is awesome, it's the difference between the cylinders that i'm concerned about. And service limit is 121.
MOD LIST:
Old 07-13-2005, 04:10 PM
96spyderman's Avatar
96spyderman 96spyderman is offline
Send a message via AIM to 96spyderman Send a message via MSN to 96spyderman
isn't the best possible compression around 180?
140-155 doesn't sound that bad to me...
Just a side question for tsipsi20.... How did you do your compression test? You will get different results if the engine is warm and if it is cold... just thought i'd ask...
"A man's greatest work is to break his enemies, to drive them before him, to take from them all the things that have been theirs." -Ghengis Khan
Old 07-13-2005, 06:56 PM
1g90gsx's Avatar
1g90gsx 1g90gsx is offline
service is 121
standard is 160
1990 MIRAGE HB
4G SWAP
FMIC
ACT 2100
TIAL BOV
TIAL WASTEGATE
FIC 650"s
SX AFR
MAFT
INNOVATIVE DUEL BB TURBO
TURBONETICS MANIFOLD
255 PUMP
WISECO 8:51
EAGLE RODS
DELTA 272 CAMS
SETRAB OIL COOLER
AEROMOTIVE STARLITE HOSE
AUTOMETER
ROTA CIRCUT 8"S
Old 07-13-2005, 07:12 PM
macder macder is offline
Send a message via MSN to macder
This is a snapshot taken from Mitchell1
This shows the minimum compression, did a full search on Mitchell1 and it does not show the recommended compression.
From the looks of it, 6-bolt turbo minimum compression is 114psi, while the 7-bolt turbo minimum compression is 121psi.
1993 Eagle Talon ES (4g63NA)
14.6 @ 98 mph (110 octane race fuel)
-5 Speed Transmission (From a 4g67)
-Stage 2 Crane cams
-Ported and polished head
-Aggresive valve springs
-2.5" Custom made exhaust piping
-Custom header
-Gutted catalytic converter
-Bored 0.5mm
-Advanced ignition timing (CAS) aprox. 5 degrees (set @ ~10deg BTDC)
-2g valve lifters (Lifter noise returned, now it a true DSM)
-K&N w/modified air canister
Old 07-14-2005, 10:01 AM
scottsee scottsee is offline
Send a message via AIM to scottsee
im going to take a stab in the dark. im thinking carbon deposits. try some seafoam.
DSM geek
Old 07-14-2005, 03:02 PM
I actually just did the seafoam thing about a month ago. Fed it through the vaccum line from the BOV to the intake manifold. I've changed the oil and filter since, so I doubt it was smoking because of the seafoam.
MOD LIST:
Old 07-14-2005, 03:05 PM
Oh and I tested it with the engine at nearly operating temperature, with the TB wide open. It was a dry test though, i didn't see the need to pour any oil down the spark plug holes to test the rings because the compression was already high enough in my opinion. The first compression stroke shot to about 70 psi, so i doubt the ring is the problem.
MOD LIST:
Old 07-14-2005, 06:09 PM
sorry i was skimming. well. might be coolant from a leaky head gasket. could have a bad cat.
DSM geek
Old 07-14-2005, 09:56 PM
97GSTspyder's Avatar
97GSTspyder 97GSTspyder is offline
Send a message via AIM to 97GSTspyder
good, i was about to post a thread similar to this one....i ran a compression test on my car today. had a buddy help me do it. my compression reads 145 for all 4 cylinders...do i have a problem here or what? i thought i should be somewhere around 175 or so. at least i'm not around 120. any help would be great.
Old 07-15-2005, 01:03 AM
That's damn good compression. Especially since it's consistent in all 4 cylinders, unlike my test. Standard compression is 164 psi, with the service limit being 121. You're on the better end of the spectrum, I'd take that anyday!
MOD LIST:
Old 07-15-2005, 03:13 PM
Originally Posted by tsipsi20
Standard compression is 164 psi, with the service limit being 121...
Just to clear things up(again), you have a 1990 DSM which has a 6-bolt, meaning the service limit is 114psi. 121psi is the service limit for a 7-bolt, as I have mentioned in the last post.
-Stage 2 Crane cams
-Custom header
-Bored 0.5mm
Old 07-15-2005, 09:12 PM
Yes, my bad, thanks!
MOD LIST:
