Go Back   Automotive Forums Car Chat > Buick > Century
Old 07-12-2005, 07:00 PM
GregB GregB is offline
Question Turn signals do not work
I have a 1991 Buick Century. The turn signals today did not work. I checked the hazard lights and lights and they all work. I suspect it is the turn signal switch. I have two questions. Is the switch located in the steering column? And, and how do you get to it? Any insight will be appreciated.
Old 07-13-2005, 12:08 AM
94century's Avatar
94century 94century is offline
First, does the turn signal stalk click and hold itself like normal, or does it move freely in either direction. It sounds like a turn signal cam broke. It is a plastic ring that goes in behind the steering wheel.
Old 07-13-2005, 05:02 AM
Re: Turn signals do not work
The turn signal stalk does click and hold itself like normal. This leads me to believe it is not the cam if I am interpreting your response correctly. By the way, it is not the fuse as I checked it.
Old 07-13-2005, 05:32 AM
Flatrater's Avatar
Flatrater Flatrater is offline
Main GM Guy
Are you sure your problem isn't in the turn signal flasher?
You can swap the turn flasher with the hazard flasher to see it makes a difference.
Shop Foreman Buick Pontiac and GMC dealership
ASE Master Tech
ASE Advanced L1
GM Master tech
Licensed Aviation mechanic
Old 07-13-2005, 12:39 PM
Mailman1 Mailman1 is offline
If the flasher is ok you should be able to hear it clicking when you move the signal lever either way. Does the signal indicator light come on but does flash? If this happens it could be a burnt out bulb.
Old 07-16-2005, 02:00 PM
Re: Re: Turn signals do not work
Ok, I am thinking it may be the flasher. Where can I find it on a 91 Buick Century?
Old 07-25-2005, 01:40 AM
Alibi's Avatar
Alibi Alibi is offline
Send a message via Yahoo to Alibi
The flasher is a small probably alumunum colored cylander, possbly yellow plastic. It is about the same diameter as a half dollar and is about an inch and a half tall. To get to it, you have to remove the lower portion of the dash under your steering wheel and fish around for it. It should have a metal clip on it. There are two--one for your blinkers and one for your hazards so you have to make sure you get the right one. They are only 2 or 3 dollars at a parts store.
-Eric
89 LeSabre T-Type: CAI, STB, F41 Suspension, Moog Ball joints and tie rods, dual-out flowmaster and dual tips, Pointiac CD HU, Delco type 2 Ignition, etc.
Basic H/C body info:http://www.3800power.bravehost.com/index.htm
http://www.cardomain.com/ride/2318168
Old 07-25-2005, 04:48 PM
Thank you for the tip and advice. I had previously found it under the dash just as you suggested. Once I replaced the flasher, the blinkers worked perfectly. Purchased the flasher at my local NAPA dealer for $3 and it took me 10 minutes at most to make the switch. Thanks again for all of the help.
