Old 07-12-2005, 07:02 PM
blazee's Avatar
blazee blazee is offline
Problem?
Thumbs up ***List Of OBD II Codes***
I composed this list for the forums that I frequent and thought it may be useful here, too.
P0001 - Fuel Volume Regulator Control Circuit/Open
P0002 - Fuel Volume Regulator Control Circuit Range/Performance
P0003 - Fuel Volume Regulator Control Circuit Low
P0004 - Fuel Volume Regulator Control Circuit High
P0005 - Fuel Shutoff Valve "A" Control Circuit/Open
P0006 - Fuel Shutoff Valve "A" Control Circuit Low
P0007 - Fuel Shutoff Valve "A" Control Circuit High
P0008 - Engine Positions System Performance Bank 1
P0009 - Engine Position System Performance Bank 2
P0010 - "A"Camshaft Position Actuator Circuit Bank 1
P0011 - "A" Camshaft Position - Timing Over - Advanced or System Performance Bank 1
P0012 - "A" Camshaft Position - Time Over - Retarded Bank 1
P0013 - "B" Camshaft Position - Actuator Circuit Bank 1
P0014 - "B" Camshaft Position - Timing Over - Advanced or System Performance Bank 1
P0015 - "B" Camshaft Position - Timing Over - Retarded Bank 1
P0016 - Crankshaft Position - Camshaft Position Correlation Bank 1 Sensor A
P0017 - Crankshaft Position - Camshaft Position Correlation Bank 1 Sensor B
P0018 - Crankshaft Position - Camshaft Position Correlation Bank 2 Sensor A
P0019 - Crankshaft Position - Camshaft Position Correlation Bank 2 Sensor B
P0020 - "A" Camshaft Position Actuator Circuit Bank 2
P0021 - "A" Camshaft Position - Timing Over - Advanced or System Performance Bank 2
P0022 - "A" Camshaft Position - Timing Over - Retarded Bank 2
P0023 - "B" Camshaft Position - Actuator Circuit Bank 2
P0024 - "B" Camshaft Position - Timing Over - Advanced or System Performance Bank 2
P0025 - "B" Camshaft Position - Timing Over - Retarded Bank 2
P0026 - Intake Valve Control Solenoid Circuit Range/Performance Bank 1
P0027 - Exhaust Valve Control solenoid Circuit Range/Performance Bank 1
P0028 - Intake valve Control Solenoid Circuit Range/Performance Bank 2
P0029 - Exhaust Valve Control Solenoid Circuit Range/Performance Bank 2
P0030 - HO2S Heater Control Circuit Bank 1 Sensor 1
P0031 - HO2S Heater Circuit Low Voltage Bank 1 Sensor 1
P0032 - HO2S Heater Circuit High Voltage Bank 1 Sensor 1
P0033 - Turbo Charger Bypass Valve Control Circuit
P0034 - Turbo Charger Bypass Valve Control Circuit Low
P0035 - Turbo Charger Bypass Valve Control Circuit High
P0036 - HO2S Heater Control Circuit Bank 1 Sensor 2
P0037 - HO2S Heater Circuit Low Voltage Bank 1 Sensor 2
P0037 - HO2S Heater Control Circuit Low Bank 1 Sensor 2
P0038 - HO2S Heater Control Circuit High Bank 1 Sensor 2
P0039 - Turbo/Super Charger Bypass Valve Control Circuit Range/Performance
P0040 - O2 Sensor Signals Swapped Bank 1 Sensor /Bank 2 Sensor 1
P0043 - HO2S Heater Control Circuit Low (bank 1, sensor 3)
P0044 - HO2S Heater Control Circuit High (bank 1, sensor 3)
P0050 - HO2S Heater Control Circuit Bank 2 Sensor 1
P0051 - HO2S Heater Control Circuit Low Bank 2 Sensor 1
P0052 - HO2S Heater Control Circuit High Bank 2 Sensor 1
P0053 - HO2S Heater Resistance Bank 1 Sensor 1
P0054 - HO2S Heater Resistance Bank 1 Sensor 2
P0055 - HO2S Heater Resistance Bank 1 Sensor 3
P0056 - HO2S Heater Control Circuit Bank 2 Sensor 2
P0057 - HO2S Heater Conrol Circuit Low Bank 2 Sensor 2
P0058 - HO2S Heater Control Circuit High Bank 2 Sensor 2
P0059 - HO2S Heater Resistance Bank 2 Sensor 1
P0060 - HO2S Heater Resistance Bank 2 Sensor 2
P0061 - HO2S Heater Resistance Bank 2 Sensor 3
P0062 - HO2S Heater Control Circuit Bank 2 Sensor 3
P0063 - HO2S Heater Control Circuit Low Bank 2 Sensor 3
P0064 - HO2S Heater Control Circuit Low Bank 2 Sensor 3
P0065 - Air Assisted Injector Control Range/Performance
P0066 - Air Assisted Injector Control Circuit or Circuit Low
P0067 - Air Assisted Injector Control Circuit High
P0068 - MAP/MAF - Throttle Position Correlation
P0069 - Manifold Absolute Pressure - Barometric Pressure Correlation
P0070 - Ambient Air Temperature Sensor Circuit
P0071 - Ambient Air Temperature Sensor Range/Performance
P0072 - Ambient Air Temperature Sensor Circuit Low
P0073 - Ambient Air Temperature Sensor Circuit High
P0074 - Ambient Air Temperature Sensor Intermittent
P0075 - Intake Valve Control Solenoid Circuit Bank 1
P0076 - Intake valve Control Solenoid Circuit Low Bank 1
P0077 - Intake Valve Control Solenoid Circuit High Bank 1
P0078 - Exhaust Valve Control Solenoid Circuit Bank 1
P0079 - Exhaust Valve Control Solenoid Circuit Low Bank 1
P0080 - Exhaust Valve Control Solenoid Circuit High Bank 1
P0081 - Intake Valve Control Solenoid Circuit Bank 2
P0082 - Intake Valve Control Solenoid Circuit Low Bank 2
P0083 - Intake Valve Control Solenoid Circuit High Bank 2
P0084 - Exhaust Valve Control Solenoid Circuit Bank 2
P0085 - Exhaust Valve Control Solenoid Circuit Low Bank 2
P0086 - Exhaust Valve Contrtol Solenoid Circuit High Bank 2
P0087 - Fuel Rail/System Pressure - Too Low
P0088 - Fuel Rail/System Pressure - Too High
P0089 - Fuel Pressure Regulator 1 Performance
P0090 - Fuel Pressure Regulator 1 Control Circuit
P0091 - Fuel Pressure Regulator 1 Control Circuit Low
P0092 - Fuel Pressure Regulator 1 Control Circuit High
P0093 - Fuel System Leak Detected - Large Leak
P0094 - Fuel System Leak Detected - Small Leak
P0095 - Intake Air Temperature Sensor 2 Circuit
P0096 - Intake Air Temperature Sensor 2 Circuit Range/Performance
P0097 - Intake Air Temperature Sensor 2 Circuit Low
P0098 - Intake Air Temperature Sensor 2 Circuit High
P0099 - Intake Air Temperature Sensor 2 Circuit Intermittent/Erratic
P0100 - MAF Sensor Circuit Insufficient Activity
P0101 - Mass Air Flow System Performance
P0102 - Mass Air Flow Sensor Circuit Low Frequency
P0103 - Mass Air Flow Sensor Circuit High Frequency
P0104 - Mass Air Flow Circuit Intermittent
P0105 - Manifold Absolute Pressure Sensor Circuit Insufficient Activity
P0106 - Manifold Absolute Pressure System Performance
P0107 - Manifold Absolute Pressure [MAP] Sensor Circuit Low Voltage
P0108 - Manifold Absolute Pressure [MAP] Sensor Circuit High Voltage
P0109 - Manifold Absolute Pressure Circuit Intermittent
P0110 - Intake Air Temperature Circuit
P0111 - Intake Air Temperature Circuit Range/Performance
P0112 - Intake Air Temperature [IAT] Sensor Circuit Low Voltage
P0113 - Intake Air Temperature [IAT] Sensor Circuit High Voltage
P0114 - Intake Air Temperature Circuit Intermittent
P0115 - ECT Sensor Circuit
P0115 - Engine Coolant Temperature Sensor Circuit
P0116 - Engine Coolant Temperature Sensor Circuit Performance
P0117 - Engine Coolant Temperature [ECT] Sensor Circuit Low Voltage
P0118 - Engine Coolant Temperature [ECT] Sensor Circuit High Voltage
P0119 - Engine Coolant Temperature Circuit Intermittent
P0120 - Throttle Position [TP] Sensor Circuit
P0121 - Throttle Position Sensor A Circuit Range/Performance
P0122 - Throttle Position Sensor Circuit Low Voltage
P0123 - Throttle Position Sensor Circuit High Voltage
P0124 - Throttle Position Sensor A Intermittent
P0125 - Engine Coolant Temperature [ECT] Excessive Time To Closed Loop Fuel Control
P0126 - Insufficent Engine Coolant Temperature for Stable Operation
P0127 - Intake Air Temperature Too High
P0128 - Coolant Thermostat (Coolant Temp Below Thermostat Regulating Temperature)
P0130 - HO2S Circuit Bank 1 Sensor 1
P0131 - HO2S Circuit Low Voltage Bank 1 Sensor 1
P0132 - HO2S Circuit High Voltage Bank 1 Sensor 1
P0133 - HO2S Slow Response Bank 1 Sensor 1
P0134 - HO2S Circuit Insufficient Activity Bank 1 Sensor 1
P0135 - HO2S Heater Circuit Bank 1 Sensor 1
P0137 - HO2S Circuit Low Voltage Bank 1 Sensor 2
P0138 - HO2S Circuit High Voltage Bank 1 Sensor 2
P0139 - HO2S Slow Response Bank 1 Sensor 2
P0140 - HO2S Circuit Insufficient Activity Bank 1 Sensor 2
P0141 - HO2S Heater Circuit Bank 1 Sensor 2
P0142 - HO2S Circuit Bank 1 Sensor 3
P0143 - HO2S Circuit Low Voltage Bank 1 Sensor 3
P0144 - HO2S Circuit High Voltage Bank 1 Sensor 3
P0145 - HO2S Circuit Bank 1 Sensor 2 Slow Response
P0146 - HO2S Circuit Insufficient Activity Bank 1 Sensor 3
P0147 - HO2S Heater Circuit Bank 1 Sensor 3
P0150 - HO2S Circuit Bank 2 Sensor 1
P0151 - HO2S Circuit Low Voltage Bank 2 Sensor 1
P0152 - HO2S Circuit High Voltage Bank 2 Sensor 1
P0153 - HO2S Slow Response Bank 2 Sensor 1
P0154 - HO2S Circuit Insufficient Activity Bank 2 Sensor 1
P0155 - Heated Oxygen Sensor Heater Circuit (bank 2, sensor 1)
P0156 - HO2S Circuit Bank 2 Sensor 2
P0157 - HO2S Circuit Low Voltage Bank 2 Sensor 2
P0158 - HO2S Circuit High Voltage Bank 2 Sensor 2
P0159 - HO2S Slow Response Bank 2 Sensor 2
P0160 - HO2S Circuit Insufficient Activity Bank 2 Sensor 2
P0161 - HO2S Heater Circuit Bank 2 Sensor 2
P0162 - HO2S Circuit Bank 2 Sensor 3
P0163 - HO2S Circuit Bank 2 Sensor 3 Low Voltage
P0164 - HO2S Circuit Bank 2 Sensor 3 High Voltage
P0165 - HO2S Circuit Bank 2 Sensor 3 Slow Response
P0166 - HO2S Circuit Bank 2 Sensor 3 No Activity
P0167 - HO2S Heater Circuit Bank 2 Sensor 3
P0169 - Fuel Composition Sensor
P0170 - Fuel Trim Bank 1
P0171 - Fuel Trim System Lean Bank 1
P0172 - Fuel Trim System Rich Bank 1
P0174 - Fuel Trim System Lean Bank 2
P0175 - Fuel Trim System Rich Bank 2
P0176 - Fuel Composition Sensor Circuit
P0177 - Fuel Composition Sensor Circuit Performance
P0178 - Fuel Composition Sensor Circuit Low Voltage
P0179 - Fuel Composition Sensor Circuit High Voltage
P0180 - Fuel Temperature Sensor A Circuit
P0181 - Fuel Temperature Sensor A Circuit Range/Performance
P0182 - Fuel Temperature Sensor A Circuit Low Input
P0183 - Fuel Temperature Sensor A Circuit High Input
P0184 - Fuel Temperature Sensor 1 Circuit Intermittent
P0185 - Fuel Temperature Sensor 2 Circuit
P0186 - Fuel Temperature Sensor B Circuit Range/Performance
P0187 - Fuel Temperature Sensor B Circuit Low Input
P0189 - Fuel Temperature Sensor 2 Circuit Intermittent
P0190 - Fuel Rail Pressure Sensor Circuit
P0191 - Fuel Rail Pressure Sensor Circuit Performance
P0192 - Fuel Rail Pressure Sensor Circuit Low Voltage
P0193 - Fuel Rail Pressure Sensor Circuit High Voltage
P0194 - Fuel Rail Pressure Sensor Circuit Intermittent
P0195 - Engine Oil Temperature Sensor Circuit
P0196 - Engine Oil Temperature Sensor Performance
P0197 - Engine Oil Temperature Sensor Low Voltage
P0198 - Engine Oil Temperature Sensor High Voltage
P0199 - Engine Oil Temperature Sensor Intermittent
P0200 - Injector Control Circuit Voltage
P0201 - Injector 1 Control Circuit
P0202 - Injector 2 Control Circuit
P0203 - Injector 3 Control Circuit
P0204 - Injector 4 Control Circuit
P0205 - Injector 5 Control Circuit
P0206 - Injector 6 Control Circuit
P0207 - Injector 7 Control Circuit
P0208 - Injector 8 Control Circuit
P0209 - Injector 9 Control Circuit
P0210 - Injector 10 Control Circuit
P0211 - Injector 11 Control Circuit
P0212 - Injector 12 Control Circuit
P0213 - Cold Start Injector 1
P0214 - Cold Start Injector 2
P0215 - Engine Shutoff Control Circuit
P0216 - Injection Timing Control Circuit
P0217 - Engine Over Temperature - Hot Light Requested
P0218 - Transmission Fluid Over Temperature
P0219 - Engine Overspeed Condition
P0220 - Throttle Position Sensor 2 Circuit
P0222 - Throttle Position Sensor B Circuit Low Voltage
P0223 - Throttle Position Sensor B Circuit High Input
P0224 - Throttle Position Sensor B Circuit Intermittent
P0225 - Throttle Position Sensor 3 Circuit
P0226 - Throttle Position Sensor 3 Circuit Performance
P0227 - Throttle/Pedal Position Sensor/Switch "C Circuit Low"
P0228 - Throttle/Pedal Position Sensor/Switch "C Circuit High"
P0228 - APP Sensor 3 Circuit High Voltage
P0229 - Throttle Position Sensor C Circuit Intermittent
P0230 - Fuel Pump Relay Control Circuit
P0231 - Fuel Pump Feedback Circuit Low Voltage
P0232 - Fuel Pump Feedback Circuit High Voltage
P0234 - Turbocharger Engine Overboost
P0235 - Turbocharger Boost Sensor 1 Circuit
P0236 - Turbocharger Boost Sensor 1 Performance
P0237 - Turbocharger Boost Sensor 1 Circuit Low Voltage
P0238 - Turbocharger Boost Sensor 1 Circuit High Voltage
P0239 - Turbocharger Boost Sensor 2 Circuit
P0240 - Turbocharger Boost Sensor 2 Performance
P0241 - Turbocharger Boost Sensor 2 Circuit Low Voltage
P0242 - Turbocharger Boost Sensor 2 Circuit High Voltage
P0243 - Turbocharger Boost Solenoid Control Circuit
P0244 - Turbocharger Wastegate Solenoid 1 Performance
P0245 - Turbocharger Wastegate Solenoid 1 Low Voltage
P0246 - Turbocharger Wastegate Solenoid 1 High Voltage
P0247 - Turbocharger Wastegate Solenoid 2
P0248 - Turbocharger Wastegate Solenoid 2 Performance
P0249 - Turbocharger Wastegate Solenoid 2 Low Voltage
P0250 - Turbocharger Wastegate Solenoid 2 High Voltage
P0251 - Injection Pump Fuel Metering Control A
P0252 - Injector Pump 1 Rotor/Cam Performance
P0253 - Injector Pump 1 Rotor/Cam Low Voltage
P0254 - Injector Pump 1 Rotor/Cam High Voltage
P0255 - Injector Pump 1 Rotor/Cam Intermittent
P0256 - Injector Pump 2 Rotor/Cam
P0257 - Injector Pump 2 Rotor/Cam Performance
P0258 - Injector Pump 2 Rotor/Cam Low Voltage
P0259 - Injector Pump 2 Rotor/Cam High Voltage
P0260 - Injector Pump 2 Rotor/Cam Intermittent
P0261 - Cylinder #1 Injector Circuit Low
P0262 - Cylinder #1 Injector Circuit High
P0263 - Cylinder #1 Contribution/Balance
P0264 - Cylinder #2 Injector Circuit Low
P0265 - Cylinder #2 Injector Circuit High
P0266 - Cylinder #2 Contribution/Balance
P0267 - Cylinder #3 Injector Circuit Low
P0268 - Cylinder #3 Injector Circuit High
P0269 - Cylinder #3 Contribution/Balance
P0270 - Cylinder #4 Injector Circuit Low
P0271 - Cylinder #4 Injector Circuit High
P0272 - Cylinder #4 Contribution/Balance
P0273 - Cylinder #5 Injector Circuit Low
P0274 - Cylinder #5 Injector Circuit High
P0275 - Cylinder #5 Contribution/Balance
P0276 - Cylinder #6 Injector Circuit Low
P0277 - Cylinder #6 Injector Circuit High
P0278 - Cylinder 6 Contribution/Balance
P0279 - Cylinder #7 Injector Circuit Low
P0280 - Cylinder #7 Injector Circuit High
P0281 - Cylinder 7 Contribution Balance
P0282 - Cylinder #8 Injector Circuit Low
P0283 - Cylinder #8 Injector Circuit High
P0284 - Cylinder 8 Contribution/Balance
P0285 - Injector Circuit Cylinder 9 Low Voltage
P0286 - Injector Circuit Cylinder 9 High Voltage
P0287 - Cylinder 9 Balance System
P0288 - Injector Circuit Cylinder 10 Low Voltage
P0289 - Injector Circuit Cylinder 10 High Voltage
P0290 - Cylinder 10 Balance System
P0291 - Injector Circuit Cylinder 11 Low Voltage
P0292 - Injector Circuit Cylinder 11 High Voltage
P0293 - Cylinder 11 Balance System
P0294 - Injector Circuit Cylinder 12 Low Voltage
P0295 - Injector Circuit Cylinder 12 High Voltage
P0296 - Cylinder 12 Balance System
P0298 - Engine Oil Overtemperature Condition
P0300 - Random/Multiple Cylinder Misfire Detected
P0301 - Cylinder 1 Misfire Detected
P0302 - Cylinder 2 Misfire Detected
P0303 - Cylinder 3 Misfire Detected
P0304 - Cylinder 4 Misfire Detected
P0305 - Cylinder 5 Misfire Detected
P0306 - Cylinder 6 Misfire Detected
P0307 - Cylinder 7 Misfire Detected
P0308 - Cylinder 8 Misfire Detected
P0309 - Cylinder 9 Misfire Detected
P0310 - Cylinder 10 Misfire Detected
P0311 - Cylinder 11 Misfire Detected
P0312 - Cylinder 12 Misfire Detected
P0320 - Ignition/Distributor Engine Speed Input Circuit
P0321 - Ignition/Distributor Eng. Speed Ckt. Performance
P0322 - Ignition/Distributor Engine Speed Circuit No Signal
P0323 - Ignition/Distributor Engine Speed Circuit Intermittent
P0325 - Knock Sensor 1 Circuit Bank 1
P0326 - Knock Sensor 1 Circuit Range/Performance (Bank 1)
P0327 - Knock Sensor 1 Circuit Low Input (Bank1)
P0328 - Knock Sensor 1 Circuit High Input (Bank 1)
P0329 - Knock Sensor 1 Circuit Bank 1 Intermittent
P0330 - Knock Sensor 2 Circuit Bank 2
P0331 - Knock Sensor 2 Circuit Range/Performance (Bank 2)
P0332 - Knock Sensor 2 Circuit Low Input
P0333 - Knock Sensor 2 Circuit High Input
P0334 - Knock Sensor 2 Circuit Bank 2 Intermittent
P0335 - Crankshaft Position [CKP] Sensor A Circuit
P0336 - Crankshaft Position Sensor Circuit A Range/Performance
P0337 - CKP Sensor Circuit Low Frequency
P0338 - CKP Sensor Circuit High Frequency
P0339 - CKP Sensor Circuit Intermittent
P0340 - Camshaft Position Sensor A Circuit (Bank 1 or single sensor)
P0341 - Camshaft Position Sensor A Circuit Range/Performance (Bank 1 or single sensor)
P0342 - Camshaft Position Sensor Circuit Low Voltage
P0343 - Camshaft Position Sensor Circuit High Voltage
P0344 - Camshaft Position Sensor Circuit Intermittent
P0350 - Ignition Coil Primary/Secondary Circuit
P0351 - Ignition Coil A Primary/Secondary Circuit
P0352 - Ignition Coil B Primary/Secondary Circuit
P0353 - Ignition Coil C Primary/Secondary Circuit
P0354 - Ignition Coil D Primary/Secondary Circuit
P0355 - Ignition Coil E Primary/Secondary Circuit
P0356 - Ignition Coil F Primary/Secondary Circuit
P0357 - Ignition Coil G Primary/Secondary Circuit
P0358 - Ignition Coil H Primary/Secondary Circuit
P0360 - Ignition Coil J Primary/Secondary Circuit
P0361 - Ignition Coil K Primary/Secondary Circuit
P0362 - Ignition Coil L Primary/Secondary Circuit
P0370 - Timing Reference High Resolution System Peformance
P0371 - Too Many High Resolution Signal 1 Pulses
P0372 - Too Few High Resolution Signal 1 Pulses
P0373 - Intermittent High Resolution Signal 1 Pulse
P0374 - No High Resolution Signal 1 Pulses
P0375 - Timing Reference Signal 2 High Resolution
P0376 - Too Many High Resolution Signal 2 Pulses
P0377 - Too Few High Resolution Signal 2 Pulses
P0378 - Intermittent High Resolution Signal 2 Pulse
P0380 - Glow Plug/Heater Circuit A
P0381 - Glow Plug/Heater Indicator Circuit
P0385 - Crankshaft Position Sensor Circuit B
P0386 - CKP Sensor B Circuit Performance
P0387 - Crankshaft Position Sensor 2 Circuit Low Voltage
P0388 - Crankshaft Position Sensor 2 Circuit High Voltage
P0389 - Crankshaft Position Sensor 2 Circuit Intermittent
P0400 - Exhaust Gas Recirculation Flow
P0401 - Exhaust Gas Recirculation Flow Insufficient Detected
P0402 - Exhaust Gas Recirculation Flow Excessive Detected
P0403 - Exhaust Gas Recirculation Control Circuit
P0404 - Exhaust Gas Recirculation Control Circuit Range/Performance
P0405 - Exhaust Gas Recirculation Sensor A Circuit Low
P0406 - Exhaust Gas Recirculation Sensor A Circuit High
P0407 - EGR Sensor 2 Circuit Low Voltage
P0408 - EGR Sensor 2 Circuit High Voltage
P0410 - Secondary Air Injection System
P0411 - Secondary Air Injection Incorrect Upstream Flow Detected
P0412 - Secondary Air Injection Switching Valve A Circuit
P0413 - Secondary Air Injection Switching Valve A Circuit Open
P0414 - Secondary Air Injection Switching Valve A Circuit Shorted
P0416 - Secondary Air Injection Switching Valve B Circuit Open
P0417 - Secondary Air Injection Switching Valve B Circuit Shorted
P0418 - Secondary Air Injection System Relay A Circuit
P0419 - Secondary Air Injection System Relay B Circuit
P0420 - Catalyst System Efficiency Below Threshold (Bank 1)
P0421 - Warm Up Catalyst Efficiency Below Threshold (Bank 1)
P0422 - Main TWC Efficiency Bank 1 Below Threshold
P0423 - Heated TWC Efficiency Bank 1 Below Threshold
P0424 - Heated TWC Temperature Bank 1 Below Threshold
P0426 - Catalyst Temperature Sensor Range/Performance (Bank1)
P0427 - Catalyst Temperature Sensor Low Input (Bank 1)
P0428 - Catalyst Temperature Sensor High Input (Bank 1)
P0430 - Catalyst System Low Efficiency Bank 2
P0431 - Warm Up Catalyst Efficiency Below Threshold (Bank 2)
P0432 - Main TWC Efficiency Bank 2 Below Threshold
P0433 - Heated TWC Efficiency Bank 2 Below Threshold
P0434 - Heated TWC Temperature Bank 2 Below Threshold
P0436 - Catalyst Temperature Sensor Range/Performance (Bank2)
P0437 - Catalyst Temperature Sensor Low Input (Bank 2)
P0438 - Catalyst Temperature Sensor High Input (Bank 2)
P0440 - Evaporative Emission Control System
P0441 - Evaporative Emission Control System Incorrect Purge Flow
P0442 - Evaporative Emission Control System Leak Detected (small leak)
P0443 - Evaporative Emission Control System Purge Control Valve Circuit
P0444 - Evaporative Emission Control System Purge Control Valve Circuit Open
P0445 - Evaporative Emission Control System Purge Control Valve Circuit Shorted
P0446 - Evaporative Emission Control System Vent Control Circuit
P0447 - EVAP Vent Valve Control Circuit Open
P0448 - EVAP Vent Valve Control Circuit Shorted
P0449 - EVAP Canister Vent Solenoid Valve Control Circuit
P0450 - Evaporative Emission Control System Pressure Sensor
P0451 - Evaporative Emission Control System Pressure Sensor Range/Performance
P0452 - Evaporative Emission Control System Pressure Sensor Low Input
P0453 - Evaporative Emission Control System Pressure Sensor High Input
P0455 - Evaporative Emission Control System Leak Detected (gross leak/no flow)
P0456 - Evaporative Emission Control System Leak Detected (very small leak)
P0460 - Fuel Level Sensor Circuit
P0461 - Fuel Level Sensor Circuit Range/Performance
P0462 - Fuel Level Sensor Circuit Low Voltage
P0463 - Fuel Level Sensor Circuit High Voltage
P0464 - Fuel Level Sensor Circuit Intermittent
P0465 - Purge Flow Sensor Circuit
P0466 - Purge Flow Sensor Circuit Performance
P0467 - Purge Flow Sensor Circuit Low Voltage
P0468 - Purge Flow Sensor Circuit High Voltage
P0469 - Purge Flow Sensor Circuit Intermittent
P0470 - Exhaust Pressure Sensor
P0471 - Exhaust Pressure Sensor Range/Performance
P0472 - Exhaust Pressure Sensor Low Input
P0473 - Exhaust Pressure Sensor High Input
P0474 - Exhaust Pressure Sensor Circuit Intermittent
P0475 - Exhaust Pressure Control Valve
P0476 - Exhaust Pressure Control Valve Range/Performance
P0477 - Exhaust Pressure Control Valve Circuit Low Voltage
P0478 - Exhaust Pressure Control Valve High Input
P0479 - Exhaust Pressure Control Valve Intermittent
P0480 - Coolant Fan 1 Control Circuit
P0481 - Coolant Fan Relay 2 Control Circuit
P0500 - Vehicle Speed Sensor
P0501 - Vehicle Speed Sensor Range/Performance
P0502 - Vehicle Speed Sensor Circuit Low Input
P0503 - Vehicle Speed Sensor Intermittent
P0505 - Idle Control System
P0506 - Idle Control System RPM Lower Than Expected
P0507 - Idle Control System RPM Higher Than Expected
P0508 - Idle Control System Circuit Low
P0509 - Idle Control System Circuit High
P0510 - Closed Throttle Position Switch
P0512 - Starter Request Circuit Performance
P0522 - Engine Oil Pressure Sensor Circuit Low Voltage
P0523 - Engine Oil Pressure Sensor Circuit High Voltage
P0530 - A/C Refrigerant Pressure Sensor Circuit
P0532 - Air Conditioning [A/C] Refrigerant Pressure Sensor Circuit Low Voltage
P0533 - A/C Refrigerant Pressure Sensor Circuit High Voltage
P0533 - Air Conditioning [A/C] Refrigerant Pressure Sensor Circuit High Voltage
P0534 - Air Conditioner Refrigerant Charge Loss
P0541 - Intake Air Heater Circuit Low
P0542 - Intake Air Heater Circuit High
P0550 - Power Steering Pressure Sensor Circuit
P0551 - Power Steering Pressure Sensor Circuit Range/Performance
P0552 - Power Steering Pressure Sensor Circuit Low Voltage
P0553 - Power Steering Pressure Sensor Circuit High Voltage
P0554 - Power Steering Pressure Sensor Circuit Intermittent
P0560 - System Voltage
P0561 - System Voltage Unstable
P0562 - System Voltage Low
P0563 - System Voltage High
P0565 - Cruise Control ON Signal
P0566 - Cruise Control OFF Signal
P0567 - Cruise Control RESUME Signal
P0568 - Cruise Control SET Signal
P0569 - Cruise Control COAST Signal
P0570 - Cruise Control ACCEL Signal
P0571 - Cruise Control Brake Switch A Circuit
P0572 - Cruise Brake Switch 1 Circuit Low Voltage
P0573 - Cruise Brake Switch 1 Circuit High Voltage
P0574 - Cruise Control System - Vehicle Speed Too High
P0600 - Serial Communication Link
P0601 - Internal Control Module Memory Check Sum Error
P0602 - Powertrain Control Module Programming Error
P0603 - Powertrain Control Module Keep Alive Memory (KAM) Error
P0604 - Internal Control Module Random Access Memory Error
P0605 - Powertrain Control Module Read Only Memory (ROM) Error
P0606 - ECM/PCM Processor
P0608 - Vehicle Speed Output Circuit
P0615 - Starter Relay Control Circuit
P0620 - Generator Control Circuit
P0621 - GEN Lamp 'L' Control Circuit
P0622 - GEN Field 'F' Control Circuit
P0636 - Power Steering Control Circuit Low
P0637 - Power Steering Control Circuit High
P0640 - Intake Air Heater Control Circuit
P0645 - A/C Clutch Relay Control Circuit
P0646 - A/C Clutch Relay Circuit Low Voltage
P0647 - A/C Clutch Relay Circuit High Voltage
P0650 - Malfunction Indicator Lamp (MIL) Control Circuit
P0654 - Engine Speed Output Circuit
P0656 - Fuel Level Output Circuit
P0660 - Intake Manifold Tuning Valve Control Circuit - Bank 1
P0661 - Intake Manifold Tuning Valve Control Circuit Low - Bank 1
P0662 - Intake Manifold Tuning Valve Control Circuit High - Bank 1
P0666 - PCM/ECM/TCM Internal Temperature Sensor Circuit
P0670 - Glow Plug Module Control Circuit
P0671 - Cylinder 1 Glow Plug Circuit
P0672 - Cylinder 2 Glow Plug Circuit
P0673 - Cylinder 3 Glow Plug Circuit
P0674 - Cylinder 4 Glow Plug Circuit
P0675 - Cylinder 5 Glow Plug Circuit
P0676 - Cylinder 6 Glow Plug Circuit
P0677 - Cylinder 7 Glow Plug Circuit
P0678 - Cylinder 8 Glow Plug Circuit
P0683 - Glow Plug Control Module to PCM Communication Circuit
P0684 - Glow Plug Control Module to PCM Communication Circuit Range/Performance
P0700 - Transmission Control System (MIL Request)
P0701 - Transmission Control System Performance
P0702 - Transmission Control System Electrical
P0703 - Brake Switch B Input Circuit
P0703 - Brake Switch Circuit
P0704 - Clutch Switch Input Circuit
P0705 - Transmission Range Sensor Circuit (PRNDL Input)
P0706 - Transmission Range Sensor Circuit Range/Performance
P0707 - Transmission Range Sensor Circuit Low Input
P0708 - Transmission Range Sensor Circuit High Input
P0709 - Transmission Range Sensor Circuit Intermittent
P0710 - Transmission Fluid Temperature Sensor Circuit
P0711 - Transmission Fluid Temperature Sensor Circuit Range/Performance
P0712 - Transmission Fluid Temperature Sensor Circuit Low Input
P0713 - Transmission Fluid Temperature Sensor Circuit High Input
P0714 - Transmission Fluid Temperature Sensor Circuit Intermittent
P0715 - Turbine Shaft Speed Sensor Circuit
P0716 - Input/Turbine Speed Sensor Circuit Performance
P0717 - Input/Turbine Speed Sensor Circuit No Signal
P0718 - Turbine Shaft Speed Sensor Circuit Intermittent
P0719 - Brake Switch 2 Circuit Low Voltage
P0720 - Output Shaft Speed Sensor Circuit
P0721 - Output Shaft Speed Sensor Circuit Range/Performance
P0722 - Output Shaft Speed Sensor Circuit No Signal
P0723 - Output Shaft Speed Sensor Circuit Intermittent
P0724 - Brake Switch 2 Circuit High Voltage
P0725 - Engine Speed Input Circuit
P0726 - Engine Speed Input Circuit Performance
P0727 - Engine Speed Circuit - No Signal
P0728 - Engine Speed Input Circuit Intermittent
P0730 - Incorrect Gear Ratio
P0731 - Gear 1 Incorrect Ratio
P0732 - Gear 2 Incorrect Ratio
P0733 - Gear 3 Incorrect Ratio
P0734 - Gear 4 Incorrect Ratio
P0735 - Gear 5 Incorrect Ratio
P0736 - Reverse Incorrect Ratio
P0740 - Torque Converter Clutch Circuit
P0741 - Torque Converter Clutch Circuit Performance Stuck Off
P0742 - Torque Converter Clutch Circuit Stuck On
P0743 - Torque Converter Clutch Circuit Electrical
P0744 - Torque Converter Clutch Circuit Intermittent
P0745 - Pressure Control Solenoid A
P0746 - Pressure Control Solenoid A Performance or Stuck Off
P0747 - Pressure Control Solenoid Stuck On
P0748 - Pressure Control Solenoid Electrical
P0749 - Pressure Control Solenoid Circuit Intermittent
P0750 - Shift Solenoid A
P0751 - Shift Solenoid A Performance or Stuck Off
P0752 - Shift Solenoid A Stuck On
P0753 - Shift Solenoid A Electrical
P0754 - 1-2 Shift Solenoid Intermittent
P0755 - Shift Solenoid B
P0756 - Shift Solenoid B Performance or Stuck Off
P0757 - Shift Solenoid B Stuck On
P0758 - Shift Solenoid B Electrical
P0761 - Shift Solenoid C Performance or Stuck Off
P0762 - 3-4 Shift Solenoid Stuck On
P0763 - Shift Solenoid C Electrical
P0764 - 3-4 Shift Solenoid Intermittent
P0765 - Shift Solenoid D
P0766 - Shift Solenoid D Performance or Stuck Off
P0767 - 4-5 Shift Solenoid Stuck On
P0768 - Shift Solenoid D Electrical
P0769 - 4-5 Shift Solenoid Intermittent
P0770 - Shift Solenoid E
P0772 - Shift Solenoid E Stuck On
P0773 - Shift Solenoid E Electrical
P0774 - Shift Solenoid 5 Intermittent
P0775 - Pressure Control Solenoid B
P0779 - Pressure Control Solenoid B Intermittent
P0780 - Shift
P0781 - 1-2 Shift
P0782 - 2-3 Shift
P0783 - 3-4 Shift
P0784 - 4-5 Shift
P0785 - Shift Timing Solenoid
P0786 - Shift Timing Solenoid Performance
P0787 - Shift Timing Solenoid Low Voltage
P0788 - Shift Timing Solenoid High Voltage
P0789 - Shift Timing Solenoid Intermittent
P0790 - Normal/Performance Switch Circuit
P0791 - Intermediate Shaft Speed Sensor Circuit
P0794 - Intermediate Shaft Speed Sensor Circuit Intermittent
P0795 - Pressure Control Solenoid C
P0796 - Pressure Control Solenoid C Performance or Stuck Off
P0797 - Pressure Control Solenoid C Stuck On
P0799 - Pressure Control Solenoid C Intermittent
P0801 - Reverse Inhibit Control Circuit
P0803 - 1-4 Upshift (Skip Shift) Solenoid Control Circuit
P0804 - 1-4 Upshift (Skip Shift) Lamp Control Circuit
P0812 - Reverse Input Circuit
P0814 - Transmission Range Display Circuit
P0815 - Upshift Switch Circuit
P0816 - Downshift Switch Circuit
P0818 - Driveline Disconnect Switch Input Circuit
P0840 - Transmission Fluid Pressure Sensor/Switch A Circuit
P0841 - Transmission Fluid Pressure Sensor/Switch A Circuit Range/Performance
P0844 - Transmission Fluid Pressure Sensor/Switch A Circuit Intermittent
P0846 - Transmission Fluid Pressure Sensor/Switch B Circuit Range/Performance
P1107 - Manifold Absolute Pressure (MAP) sensor circuit intermittent low voltage
P1111 - Intake Air Temperature (IAT) sensor circuit intermittent high voltage
P0112 - Intake Air Temperature (IAT) sensor circuit intermittent low voltage
P0114 - Engine Coolant Temperature (ECT) sensor circuit intermittent low voltage
P0115 - Engine Coolant Temperature (ECT) sensor circuit intermittent high voltage
P1121 - Throttle Position (TP) sensor circuit intermittent high voltage
P1122 - Throttle Position (TP) sensor circuit intermittent low voltage
P1133 - Heated Oxygen Sensor (HO2S) insufficient switching Bank 1 sensor 1
P1134 - Heated Oxygen Sensor (HO2S) transition time ratio Bank 1 sensor 1
P1153 - Heated Oxygen Sensor (HO2S) insufficient switching Bank 2 sensor 1
P1154 - Heated Oxygen Sensor (HO2S) transition time ratio Bank 2 sensor 1
P1171 - Fuel system lean during acceleration
P1222 - Injector control circuit intermittent
P1351 - Ignition Control (IC) circuit high voltage (open circuit)
P1361 - Ignition Control (IC) circuit high voltage (shorted or grounded circuit)
P1371 - Distributor Ignition (DI) low resolution circuit
P1380 - EB(T)CM DTC detected-rough road data unusable
P1381 - Misfire detected-no EB(T)CM/PCM serial data
P1415 - Secondary Air Injection (AIR) system Bank 1
P1416 - Secondary Air Injection (AIR) system Bank 2
P1441 - Evaporative Emissions (EVAP) system flow during non-purge
P1506 - Idle Air Control (IAC) system low RPM
P1509 - Idle Air Control (IAC) system high RPM
P1532 - A/C Evaporator Temperature sensor circuit low voltage
P1533 - A/C Evaporator Temperature sensor circuit high voltage
P1539 - A/C clutch status circuit high voltage
P1543 - A/C system performance
P1545 - A/C clutch relay control circuit
P1546 - A/C clutch status circuit low voltage
P1572 - Traction Control System (ASR/TCS) active circuit low voltage too long
P1626 - Theft deterrent system fuel enable circuit
P1641 - Fan Control (FC) relay 1 control circuit
P1642 - Fan Control (FC) relay 2 and 3 control circuit
P1643 - Engine speed (RPM) output circuit
P1652 - Vehicle Speed Sensor (VSS) output circuit
P1657 - Skip shift/One to four upshift system control circuit
P1661 - Malfunction Indicator Lamp (MIL) control circuit
P1664 - Skip shift/One to four upshift upshift lamp control circuit
P1667 - Reverse inhibit solenoid control circuit
P1810 - Pressure Switch Assembly (PSA) Circuit Malfunction
P1812 - Transmission Fluid Overtemperature
P1860 - TCC PWM Solenoid Circuit – Electrical
P1864 - TCC Solenoid Circuit – Electrical
P1870 - Transmission Component Slipping
P1886 - 3-2 Control Solenoid Circuit – Electrical
If you see any that I missed, let me know and i will amend the list.
Old 07-12-2005, 08:02 PM
Mr. Luos's Avatar
Mr. Luos Mr. Luos is offline
Firebird Guy
Re: ***List Of OBD II Codes***
Those are the ones I was throwing....there is one more as well. Something to do with the computer not able to rear air/fuel properly.
1999 Pontiac Trans Am WS.6 #1747
Stock'ish'
Old 07-12-2005, 08:09 PM
Viper_Storm's Avatar
Viper_Storm Viper_Storm is offline
Send a message via AIM to Viper_Storm Send a message via MSN to Viper_Storm
thats a big ass list, nice job dude.
All Throttle, No Bottle!
Torque Makes You Go... FAST!
Horsepower Is For Braggin Rights.
Money talks, But all mine ever says is Goodbye
~Viper
"twospirts" / "TS" - Definition: Obsolete
Old 07-12-2005, 10:14 PM
blindeyed's Avatar
blindeyed blindeyed is offline
eBay aDdict™
Send a message via AIM to blindeyed
Bored were we? Now you should go ahead and start workin on the list of OBD I codes, lol jp.
- Jason
1995 Pontiac Firebird
User Guidelines | VB Codes Explained | AF Merchandise
"Each of us, is in the scheme of things, insignificant.
But millions of insignificant people, doing a tiny bit,
can add up to be a very significant force."
Old 07-13-2005, 05:22 PM
Savage Messiah's Avatar
Savage Messiah Savage Messiah is offline
Send a message via AIM to Savage Messiah Send a message via Yahoo to Savage Messiah
Awesome, thanks a lot
97 Camaro - 2.077 60', 14.745 @ 92.20 - still down, one year later.
194k miles-160* thermo-V8 shocks/springs (V6 rear springs)-3" Magnaflow !cat (3" dynomax bullet) back-SLP CAI-stock boxed LCAs-poly tranny mount and torque arm bushing-custom HPTuners tuning-4.10s/eaton/TA girdle-3.5" alum DS-spohn LCA brackets-prostar skinnies
179.75 RWHP, 204.52 RWTQ
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
01 EX250 - still gotta get my license for this thing
Old 07-13-2005, 06:34 PM
blazee's Avatar
Problem?
You're welcome guys. I hope they come in handy.
Here you go:
http://www.automotiveforums.com/vbul....php?p=3238285
Old 07-13-2005, 11:07 PM
blindeyed's Avatar
eBay aDdict™
Re: Re: ***List Of OBD II Codes***
Here you go:
Wow, I was just joking around. But that's pretty cool of ya, thank's alot for that.
- Jason
