Old 07-12-2005, 09:01 AM
robjen robjen is offline
Laptop, monitoring
Is there a way to monitor the engine using a laptop. Also can you make changes using it to.
Thanx in advance.
Ive got a 2005 5.3 vortec in a silverado crew cab
Old 07-12-2005, 09:17 AM
BlenderWizard's Avatar
BlenderWizard BlenderWizard is offline
Send a message via AIM to BlenderWizard
Re: Laptop, monitoring
Yeah, you need a program called ls1edit. It's expensive though - like $2,000 if i remember right
"When I step on the gas, I want people to think the world is coming to an end!" - Homer Simpson
2002 ECSB, Nelson Tune, LS1 electric fans, 145A alternator, K&N FIPK, 160º T-stat, TB coolant bypass, Corvette servo, 4 headlight mod, blue LED gauge cluster
Old 07-12-2005, 09:39 AM
dr_of_lovephd dr_of_lovephd is offline
I know you can buy programs for $100-200 (maybe cheaper on ebay) that will read all of the sensors and let you monitor you performance and engine output. You can also estimate hp and torque, 0-60 times, etc. Also, some of the programs will work with PDAs as well.
But if you want one that will change the parameters you will need to buy the $2000 one.
Old 07-12-2005, 01:25 PM
Ouch, 2000, man I think I am going to have to figure out how to reverse engineer those things. As with most electronics, you could probably build one for 5 worth of radio shack parts.
Thanks for the replies
Old 07-12-2005, 02:24 PM
ls1edit is a software program. It is expensive; it's what performance shops use to give you a tune.
Old 07-18-2005, 11:15 PM
rrousou rrousou is offline
check out: autotap.com
looks relatively good and very affordable, even works with palm pilots
Old 07-19-2005, 01:08 AM
mjgjr72 mjgjr72 is offline
there are a few programs that you can get for a laptop to monitor and reprogram with here are 2 popular ones
efilive
http://www.efilive.com/
hptuner
http://www.hptuners.com/
