Old 07-12-2005, 09:42 AM
wiggmr wiggmr is offline
Transmission Issues
I have a 96 Jeep Cherokee Sport and the transmission seems to be slipping a little. It was doing this several months ago and i had the transmission fluid flushed and changed along with the filter and it began working fine. It just progressively has continued to get as bad as it was before. The other day i noticed what i belived to be a little transmission fluid on the ground under my truck and i checked the levels and it was a low considering it was just replaced not long ago. It seems to only slip when i come to a stop then begin to go again. If anyone has any clues as to what it might be i would greatly appreciate it. The fluid level is just above the add line, but not close to the max fill line. NOt sure if it is the lack of fluid, but if so any clues as to where the leak could be or if i should take it back where it was replaced and have them refill it. Thanks Again for any help on the matter.
Old 09-06-2005, 02:42 PM
jeepguyxj jeepguyxj is offline
Re: Transmission Issues
well if they replaced the filter in the tranny. then the fluid leak could be coming from the tranny pan gasket. or the bolts that hold the gasket on could be loose. top off teh trans fluid and see if that makes a difference.
Old 09-06-2005, 10:25 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
In my experience, if your trans starts to slip a fluid and filter change will fix the problem only about half the time.
Either the clutch packs were too badly worn before the service was done, or there is another problem, like a bad transmission pump or a cracked drum, leaking internal seals, etc.
Try putting about 1 oz of clean DOT 3 brake fluid into the transmission. Then add 1/4 pint of trans fluid to wash it down. The brake fluid will swell the internal seals, and might put off a major repair for a while.
IMO the only alternative is a transmission rebuild.
Old 09-09-2005, 01:15 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
If the new fluid helped before it may help again. A friend of mine was having tranny problems, he changed the fluid every time the problems returned. After 4 changes his trans was fine for the next 150K miles. Seems like the new fluid had to work its way through, then got diluted by the old fluid remaining inside. Once he'd done the 4 changes all the old fluid was out.
It's worth a try, and hella cheaper than a rebuild.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 09-13-2005, 01:32 AM
blue_74 blue_74 is offline
Hi
i just bought grand cherokee lorado 4.oL with 186000 km from a jerk old man which made me stupid.when my car get warm 2nd gear start get slip and shift fast and when i start to stop in trafic ligh the gear downshift very slow take 5 second to change in first in cold it work good so plz tell me what should i do and why it is doing like this.
Thanks
Old 09-13-2005, 01:34 AM
Re: Re: Transmission Issues
Hi
Thanks
plz help me tell me what should i do.
Old 09-18-2005, 08:47 PM
Raimundo Raimundo is offline
Originally Posted by blue_74
Hi
Thanks
Hi "blue74. Since the car is 186000 km, i recomend you to do a transmission flush and trans..filter change -at the same time-.it works good in cold 'cause the fluid viscosity is higer when cold, when it warms up it looses viscosity causin' it to slep among the tranny components.
PS. also replase all the other fluids(engine oil,transfer case grease,diferentials oil), since-I guess-,you dont know if the former owner ever did it. Good Lluck.
Old 09-19-2005, 07:05 PM
Re: Re: Re: Transmission Issues
Hi Thanks for reply can you tell me why when the jeep goes in normal temp why the trans shift properly like if i am going and stop at trafic light the trans doesnt shift 1st straight away it takes 5 second to change in first gear.and if the car cold or hot the kickdown dosent work.
Thanks again.
Old 09-19-2005, 07:09 PM
Re: Re: Re: Re: Transmission Issues
opps i mean why the trans doesnt change properly when its hot.
