Old 07-12-2005, 07:38 AM
rhb3 rhb3 is offline
braking vibration
I have a 2000 XL 4.2L F-150. It vibrates when decelerating from about 50-40 mph but only with light braking. When you decelerate rapidly, there is no noticeable vibration. Any ideas on this?
Old 03-25-2006, 10:05 AM
shmls shmls is offline
Re: braking vibration
95 150 vibration when braking
Old 03-25-2006, 10:34 PM
transgta transgta is offline
Have you turned your rotors sometimes they get hot and warp. My supercrew was bouncing in back at light braking rotors turned super smooth. I did go ahead and change pads while i did it so the pads would be equally smooth. DAVE
Old 04-02-2006, 10:39 AM
eti engineer's Avatar
eti engineer eti engineer is offline
I have a 2002 F-150 and I have gone through two sets of rotors with this miserable piece of crap. My Chevy S-10 is great. No problems with anything.
I have been told, and I don't know if this is for real, that it has to do with Ford's composite brake pistons. They expand with heat and then hold the pads out against the rotors, which exacerbates the problem -- wears the pads out prematurely and warps the rotors. I have been told to get the aftermarket calipers with metal pistons, and I won't have any problems. Seems like front ends, trannies and brakes are always a problem on Fords. Every Ford I have owned, or was given to drive from the companies I have worked for has had these same issues and more.
I will stick with Chevy, given a choice. A much better truck
later..
eti engineer
SAVE TIME AND TAX DOLLARS -- EXECUTE THE PERP, NOT THE WARRANT...
10 pm. my yard. your cat. my gun sights. (keep 'em home!!!)
Old 04-04-2006, 09:47 AM
reree reree is offline
If u kill my cat ur ass will b in jail
Old 04-09-2006, 09:37 PM
brattzzzzz brattzzzzz is offline
i changed my front brake rotors when i had this vibration
the vibration went away
Old 04-09-2006, 09:40 PM
alphalanos alphalanos is offline
Usually quality rotors and pads, along with a proper bed-in procedure will cure this. Most people dont know about the bed-in. When new brakes are used, it is necessary to deposit an equal amount of pad material on the rotor to ensure a smooth surface. I replaced my old brakes with new Brembo parts and they are as smooth as any car ive had.
96 EJ6. Future home of boosted B18C1.
Old 04-10-2006, 07:49 AM
steve longo steve longo is offline
Smile Re: braking vibration
later..
eti engineer
Maybe your just too hard on your truck---ride a bike
