Old 07-12-2005, 07:31 AM
walleyes4me walleyes4me is offline
Tire Pressure
I just bought an 2005, 2500 HD, ext cab. The tire size is 245/75R 16. The recommended pressure on the door sticker reads, 55 lbs front and 80 lbs for the rear. What tire pressures do those who have similiar trucks run?
Thanks,
Joe
Old 07-12-2005, 11:12 AM
kenny-1907's Avatar
kenny-1907 kenny-1907 is offline
Send a message via MSN to kenny-1907
Re: Tire Pressure
Best bet is to run the pressure that the door sticker says to unless you have different tires than what comes from factory, then run the pressure the tire mfg says to.
**2007 Avalanche LT. **
6" Pro Comp lift
305/55/20 BFG A/T KO'S
K&N FIPK GENII
Flo Pro V force muffler & 4" slash cut stainless tips
Color matched front and rear Bowties
3" polished stainless bull bar and Nerf bars
Old 07-12-2005, 11:18 AM
Austin8214's Avatar
Austin8214 Austin8214 is offline
Re: Re: Tire Pressure
If you rember Firestone and Ford had an arguement about this very same thing about 5 years ago. If it were me i would run the pressure that the tire mfg. has stamped in the tire.
Old 07-12-2005, 10:48 PM
White Lightening's Avatar
White Lightening White Lightening is offline
Re: Tire Pressure
I don't have your size tires - but I'm just a bit amazed at the high tire pressures you're talking about. They may be correct - but they seem very very high. I have 20 inch tires and my recommended inflation is 30 lbs front and 30 lbs rear.
Old 07-12-2005, 11:01 PM
jethro_3's Avatar
jethro_3 jethro_3 is offline
Re: Tire Pressure
I remember most of the 3/4 ton trucks on the farm from early 70's up always had 60+ psi for load capacity. You don't want to put a load in that thing and feel a soft sidewall roll when going around a corner and then loose it...... Not a good feeling watching the back end come around your front end....
Old 07-13-2005, 05:39 PM
CapriRacer CapriRacer is offline
Re: Tire Pressure
"If it were me i would run the pressure that the tire mfg. has stamped in the tire."
What's stamped on the sidewall of the tire is the maximum - not a recommendation. (even says so!)
If you're using the same size as came on the truck, regardless of who made the tire, use the pressure on the placard (the vehicle manufacturer's spec,)
BTW, Walleye's tire size is LT245/75R16. The letters are extremely important (so are the absence of letters - that means a European sizing system, and it's every so slightly different)
Hope this helps.
Old 07-14-2005, 08:29 AM
twomorestrokes's Avatar
twomorestrokes twomorestrokes is offline
Re: Tire Pressure
Joe, my '02 HD also calls for 55 front 80 rear. I run 55 all the way around in the 265's that are on it now. The HD series does not need help in the rough ride department. If 55 is enough for the front tires with the engine weight over them, 55 is more than enough for the rear when holding up an empty box. If I'm hauling something heavy, then I add air to the rear but for daily driving I appreciate the extra cush.
Old 07-14-2005, 09:14 AM
BlenderWizard's Avatar
BlenderWizard BlenderWizard is offline
Send a message via AIM to BlenderWizard
That sounds like a good idea
"When I step on the gas, I want people to think the world is coming to an end!" - Homer Simpson
2002 ECSB, Nelson Tune, LS1 electric fans, 145A alternator, K&N FIPK, 160º T-stat, TB coolant bypass, Corvette servo, 4 headlight mod, blue LED gauge cluster
Old 07-14-2005, 05:40 PM
Re: Tire Pressure
"That sounds like a good idea"
Just don't EVER forget. An overloaded tire failure is not a pretty sight. And a tire never forgets, so it might fail long after the incident.
