Go Back   Automotive Forums Car Chat > Ford > General Discussion
Old 07-12-2005, 12:40 AM
bigredcounslor bigredcounslor is offline
Question is there no one who answer my questions
i have a few Questions
1) my 95 se probe shakes and somtimes stalls when in park or if i stop
2) Is there a website or someone who can give me the directions on how to install a sunroof from a 2003 celica to my probe
3) Finall questin is there a such thing were i can go from 4 to 5 lug pattern or a adapter of somkind
any thoughts or questions would be greatly appreciated and taken to thought im lost on this one
thnx for your time and at least for reading this CSW3
Old 07-12-2005, 02:38 PM
williamskinner16 williamskinner16 is offline
Re: is there no one who answer my questions
try a normal tune up, it wont hurt and if it has been a while, It probably needs done anyway(spark plugs, wires that sort of thing) check a chilton or haynes manual for troubleshooting details. a fuel pressure gauge attatched to the schrader valve (looks like a tire valve) at the fuel injection rail will tell you if proper pressure is going to the injectors(usually 35-40psi check with a working manual to be sure) could indicate fuel pump or clogged filter. good luck.
Old 07-13-2005, 01:27 AM
drdisque's Avatar
drdisque drdisque is offline
Send a message via AIM to drdisque
I'm guessing that the stalling problem is a Vacuum leak. Chances are that sunroof will not fit on your probe. There's no real "directions" for custom fabrication like that. If you don't know how to do it, I suggest not doing it to avoid making a mess of your car. Yes, they do make adapters but they're not the safest thing to use and make the wheels stick out a little bit.
Dr. Disque -
Current cars:
2008 BMW 135i M-Sport
2011 Mazda2 Touring
Past cars:
2007 Mazda 6S 5-door MT
1999 Ford Taurus SE Duratec
Old 07-25-2005, 11:08 PM
Shatteredsoul Shatteredsoul is offline
Fords are also notorious for the IAC motor sticking and could make it stall and die like that.
Old 08-31-2005, 10:25 PM
nemo566 nemo566 is offline
The Car Dying Is The Iac. You Can Remove It And Try Cleaning The Carbon Out Of The Iac With Wd-40
