Old 07-12-2005, 12:31 AM
captain1 captain1 is offline
'94 S-10 fuel pump relay
Hello everybody,
Truck died while coming home the other morning. Turned ignition off, then immediately tried to restart and started as normal. Hooked code reader up and came back with a "Fuel Pump Relay". So, I bought a new relay, but can't find where the old one is located. A couple of weeks ago, it done the same thing, only the code reader came back with a "EGR Solenoid" code. I replaced the EGR solenoid. Could this be a computer problem? Also, where is that darn relay located? I thought that it may be one of the three black relays on the passenger side under the hood close to the firewall, but no avail. Haynes says driver side under instrument cluster close to center console, but still can't find it. Any help appreciated,
Steve
Old 07-12-2005, 05:59 AM
jackass#1's Avatar
jackass#1 jackass#1 is offline
Send a message via Yahoo to jackass#1
Re: '94 S-10 fuel pump relay
in my 91 it is under the hood right in the corner of firewall on drivers side. i noticed on a 95 there are 3 relays mounted on the wall almost center, all in a row. thats probably the ones you already tried,huh? manual said under the dash? good luck.
