Old 07-11-2005, 11:08 PM
Arsenik111 Arsenik111 is offline
Creaking noise
can someone please tell me why i hear a creaking noise every time i accelorate, brake, or go over a bump. It sounds like the suspension is stiff of something. thanx
Old 07-11-2005, 11:15 PM
BlenderWizard's Avatar
BlenderWizard BlenderWizard is offline
Send a message via AIM to BlenderWizard
Re: Creaking noise
I get a creak in my driver's side door(s) that i would like to know more about.
"When I step on the gas, I want people to think the world is coming to an end!" - Homer Simpson
2002 ECSB, Nelson Tune, LS1 electric fans, 145A alternator, K&N FIPK, 160º T-stat, TB coolant bypass, Corvette servo, 4 headlight mod, blue LED gauge cluster
Old 07-12-2005, 06:26 AM
Ape0r Ape0r is offline
Send a message via AIM to Ape0r
Re: Creaking noise
Check body mounts, was my problem. Removal and cleaning fixed it.
'04 Silverado 1500 4x4 5.3L 3.73 G80
Old 07-12-2005, 09:46 PM
airtight_python airtight_python is offline
Re: Creaking noise
I have a few squeeks and creaks in the suspension as well. I crawled under the truck with a can of WD40 and sprayed everything down. That didn't work. I was thinking maybe it's the coils up front and shocks in the rear. When I get my drop kit maybe that part will be fixed. I'm pretty much holding off on all the little things for when I get a decent job and can upgrade everything.
Old 07-13-2005, 10:23 AM
sportin83 sportin83 is offline
Send a message via AIM to sportin83 Send a message via Yahoo to sportin83
i have the creaking and i am pretty sure it is the body mounts. it didnt do it will i bolted the nerf bars to the body mounts. if i put pressure on the bars it creaks and when i hit bumps it creaks really gets annoying. my truck has 33000 miles and sounds like it has 100000. it sucks
2002 CHEVY SILVERADO
more pics at http://www.cardomain.com/ride/2228127
Old 07-13-2005, 10:31 AM
haproot's Avatar
haproot haproot is offline
Send a message via MSN to haproot
Re: Creaking noise
Leaf spring grommets maybe?? Just a thought.
Old 07-16-2005, 04:52 PM
Re: Creaking noise
never mind i figured it out. when i put the nerf bars on i didnt leave the origional washers on it and i was suposed to. also if its creaking on anyone else take out the body mount bolts, spray the bolts with wd-40 as well as inside the holes and torque the end ones at 65 ft lbs and the middle ones at 30 ft lbs.
Old 07-18-2005, 10:12 PM
any other hints on why body mounts or nerf bars creek. i am pullin my down tomorrow to see what the deal is. they drive me nuts. i know i put the washers back on but they sent new bolts with the bars and i used them instead of factory and they might be rusty or something. i dont know will find out tomorrow and try to post what was the prob.
