Go Back   Automotive Forums Car Chat > Nissan > 240Z | 260Z| 280Z | 300ZX (Past Z Cars)
240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all.
Old 07-11-2005, 11:42 PM
scott37 scott37 is offline
1984 300 zx question
I just bought this car and replaced the clutch. I was told that was the only problem but it was not. When I try to put it into 1st gear it seem like it wont go all the way in. It only goes into 5th and reverse. The other gears make a kind of grinding noise. I am hoping this is not a tranny problem but mabye just my gear shifter box. Please help. Manual 5 speed transmission
Old 07-12-2005, 01:38 PM
longlivetheZ's Avatar
longlivetheZ longlivetheZ is offline
Send a message via AIM to longlivetheZ Send a message via MSN to longlivetheZ
Re: 1984 300 zx question
Sounds like your syncros are bad. Unfortunatly, that would qualify as a "tranny problem". I don't think it's any HUGE deal to fix, but I don't think it's exactly a quicky fix, either.
However...have you checked your clutch slave cylinder? Had that go bad once and it wouldn't let me into gears, either. Will it go into gear when the car's off? The slave cylinder IS a quicky fix. Pray it's that, dude...
Who cares what's in your wallet...what's in your garage?
VG30ET in process of rebuild on left and my 88 300ZX NA, 2 Seater, 5-Speed...my 3rd Z31
Hope you can see the tiny pic...AF reduced the size limit!
Beer is living proof that God loves us and wants us to be happy. --Benjamin Franklin
Old 07-14-2005, 01:12 AM
ExTrEmEDrIfT's Avatar
ExTrEmEDrIfT ExTrEmEDrIfT is offline
Send a message via AIM to ExTrEmEDrIfT Send a message via MSN to ExTrEmEDrIfT Send a message via Yahoo to ExTrEmEDrIfT
if it was the slave cylinder though it wouldnt just let him go into just 2 gears and not the others it would react the same with all the gears
Past Z Car Crew
[The Enemy Of Your Enemy is Your Friend]
>>Keep Your Friends close : But Keep Your Enemies Even Closer <<
Old 07-14-2005, 10:27 AM
Not necessarily. Besides, he said it would only let him into 5th and reverse.
Old 07-14-2005, 10:21 PM
stephenp stephenp is offline
Send a message via AIM to stephenp
sounds like the slave
the tranny in 5th wouldnt have as much resistance a sin other gears and onse the inertia is stopped it is still stopped when you go from 5th to rev.
but when you go back to 1st the inertia of the engine starts to spin the pressure plate again and its spinning so you cant engage it
good luck
