Go Back   Automotive Forums Car Chat > Pontiac > Trans Sport
Old 07-11-2005, 09:20 PM
jcknight jcknight is offline
Send a message via AIM to jcknight
Help motor problems
I have a 94 transport it's started making a bad noise, after investigating I noticed the ac pump was siezed up and the water pump seemed to be making a rattling noise. We replaced the ac pump and the water pump and the noise is still there. I have noticed about 1 inch of play in the serpentine belt (back and forth). I'm afraid that my crank shaft is about to snap because I don't think that there is supposed to be play there. Any ideas?
Old 07-12-2005, 05:38 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Help motor problems
First of all you would not be able to determine a crankshaft problem by wiggling the serpentine belt. If anything either the idler pulley or the tensioner on the belt is going bad and needs replaced. Also there is a possibility that the belt is the wrong one for your particular engine.
Old 07-12-2005, 09:33 AM
LMP's Avatar
LMP LMP is offline
A few cases of disintegration of the crankshaft pulley that exhibited similar symptoms have been reported on this forum . So this is another possibility.
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629
I don't believe in miracles.
Old 07-13-2005, 08:40 AM
cdru's Avatar
cdru cdru is offline
Take the belt off and examine each pully individually. There shouldn't be any noticable play in any of them with the exception of the tensioner which obviously will move some.
Old 11-30-2005, 08:27 AM
boness boness is offline
I am having the same problem. I have replaced the belt tensioner and th e the the water pump, bypassed the ac pump had the altenator shop rule out the altenator and still my belt tensioner has a small play in it with a terrible rattle. I always wanted a head turner, but not from my van.... Looking for suggestions also.
Old 11-30-2005, 11:52 AM
LMP's Avatar
LMP LMP is offline
Check this out
http://www.automotiveforums.com/vbul...d.php?t=348449
