Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 07-11-2005, 09:12 PM
squibb94tbird squibb94tbird is offline
Need new back Breaks
I noticed a wile back that my emergency break light was coming on randomly when I would hit the breaks and let the peddle out quickly. So I checked my break fluid and it was fine. I dont have a manual for my 94 T bird so guess I just ignored the light. Now this past week the light is on almost more than it is off. If I push the peddle in a little when the light is on and release it really slowly the light will go off for a little wile.(Untill I push the break back in or go fast around a sharp corner.) Now I noticed that my back breaks are making a high pitched noise if I hit them somewhat hard. Oh by the way my front breaks are 4 months old and the back breaks are drum breaks. So i'm guessing i need new pads for the back, but I dont really know what i need. I believe the back pads were replaced in 1999. So my question is what do i need for break parts? Thanks again.
Old 07-12-2005, 02:14 PM
94tbirdlx2005 94tbirdlx2005 is offline
Send a message via Yahoo to 94tbirdlx2005
Re: Need new back Breaks
Someone correct me if I'm wrong, but you do need new brake shoes for the back. Be sure to readjust the tension in the back (providing your brakes need it, some tension themselves). If that doesn't work for the light problem, try bleeding and refilling your brakes.
Old 07-12-2005, 03:04 PM
97Bird's Avatar
97Bird 97Bird is offline
If the squeal you hear is from worn BRAKE shoes grinding on the drums, then you will probably need new drums also. I suggest replacing the wheel cylinders at this time, also. The brake shoes should always be adjusted out until you hear them lightly rubbing the drum when you spin the wheel before you rely on the self adjusting mechanism for final adjustment. Otherwise you may find your brake pedal going to the floor the first time you hit the brakes!
Old 07-13-2005, 12:13 PM
Re: Re: Need new back Breaks
Ok thanks alot, the only thing left i need to know is do you have any idea what all the parts will cost me?
Old 07-13-2005, 04:38 PM
97Bird's Avatar
Go to autozone.com to get prices.
Old 07-13-2005, 06:10 PM
Thank you for the help, I stoped and talk to my mechanic today and they are gonna put the breaks on next tuesday. I just got to buy the parts so i can save some money. Thanks again.
