Old 07-11-2005, 08:02 PM
bgates bgates is offline
98 lumina
does anyone know how to get the service engine soon light off ?? brought it to walmart they replaced the battery and now light wont go off they said bring it to a garage sumone said there is a code or a way to get it to shut off by turning the car off and on a certain number of times i dont want to pay 70 $ to get it put on computer can sumone help me out
Old 07-11-2005, 08:19 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: 98 lumina
bring it to autozone, they will pull the trouble code for you, tell you what it means, and reset the light. However if the problem that caused the light to come on in the first place isn't fixed, the light will only come back. Otherwise take it for two "trips". get in, start it, drive it at highway speeds for a half hour, stop, shut it off, start it up, and take it that same half hour trip again. Then shut it off and start it up, and if there aren't anymore malfunctions, this will have reset the light. Good luck. Or you can do it the easy way. Disconnect the negative battery cable for a minute or so. Sometimes this does it.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 07-14-2005, 11:36 PM
RBStratman RBStratman is offline
You could try pulling out the fuse marked PCM in the fuse panel for a few seconds. This will be the same as pulling the battery cable.Or.... You can also buy a code reader for $120 and read the code yourself and then the code reader allows you to reset the light. The code readers come with an extensive manual to tell you what each code means. They are a worthwhile investment as they will be OBDII compatable (as are all cars after 95 or 96..I forget what year) and you can work on any car after 95 or 96 with the OBDII code readers.
