Old 07-11-2005, 06:53 PM
frostie frostie is offline
C1185 Code
Finally had my ABS codes read. ABS and TRAC OFF lights were coming on intermittently. I am getting a C1185 code (ABS Power Relay Output Circuit Failure) plus 2 codes on each wheel (inlet and outlet valve circuit failure).
Question: Should I buy the ABS relay for about $10 ( but I have no clue where it goes) or do I need a whole new ABS module? All suggestions welcome!
Thanks.
Old 07-11-2005, 11:02 PM
hueroloco hueroloco is offline
Re: C1185 Code
the ABS relay is actually an internal relay in the ABS module. That code, C1185, is usually an indication of a bad module or bad power or ground to the module.
