Old 07-11-2005, 06:30 PM
pimpcrx_kid pimpcrx_kid is offline
Send a message via AIM to pimpcrx_kid Send a message via Yahoo to pimpcrx_kid
wich injectors
if you have a d16z6 head (92-95 civic ex)in a crx si would you gain anything by using the d16z6 injectors and unplugging the resistor box?or are the injectors the same...write now im using the d16z6 head and the d16a6(88-91 crx/civic si) injectors,dizzy,ecu,and intake
Old 07-11-2005, 07:34 PM
slammedcivicsi's Avatar
slammedcivicsi slammedcivicsi is offline
Re: wich injectors
the injectors are OBD 1.....so they wont work....and even if they did they are the same CC....so there would be no point in switching over unless yours had a problem with them.
89 DX: LS Powered
88 CX: Project ZC
Old 07-12-2005, 01:11 AM
duffman868 duffman868 is offline
Re: wich injectors
i know that you can use either obd1 or obd2 injecters without the resister box but can remember which one but no performance out of it
1990 Honda Civic std - ls swap
1994 Eagle Talon dl - daily driver and slow as balls
I should make a paper mache turbo and manifold.. I shall call it.. the SSAutoMache
