Old 07-11-2005, 06:26 PM
ndaniel7 ndaniel7 is offline
A/C Controller Problem
99' Grand Am
I had a problem with my car not blowing air at all. So I had the blower checked out then I replaced the heater and A/C controller the knobs you turn to turn the A/C and Heater on and off. So now I have air but it only blows on the highest setting.
What could be the problem?
Old 07-11-2005, 07:47 PM
Knifeblade Knifeblade is offline
Re: A/C Controller Problem
K, first, does the blower run right at all the speeds? Does the blower run at selected speed on heat through the fan range-speeds?
Old 07-11-2005, 08:06 PM
catback23 catback23 is offline
Re: Re: A/C Controller Problem
WTH, did you not read the post? The blower only works on high. I'd say you need a new blower resistor. If you have an ohmmeter you can test it but if you don't it's very probable that it's bad.
Old 07-11-2005, 08:24 PM
Hoags's Avatar
Hoags Hoags is offline
Something I ran across with my 98 Montana with the same problem (only blowing on HIGH speed). I found that the wire harness at the blower motor worked loose, I unplugged it completely and made sure there was no debris in either side and plugged it back in and all worked fine. It's worth a shot. Your's may not be the same but I thought I would offer it up any way.
Good luck.
