Go Back   Automotive Forums Car Chat > Mazda > MX-6
Old 07-11-2005, 06:11 PM
endeffect0 endeffect0 is offline
Best Exhaust?
I'm looking for a cat back exhuast for a 95 Mx6 Ls for around or under 400 that has as little restriction as posible. I know there lots out there but I want one that will give a deep agrisive sound with out being whiny. Also i hate seeing giant mufflers that are draging on the ground. what do you have on your car or what have you seen/heard that you like.
Old 07-12-2005, 12:15 AM
shawnwilliams's Avatar
shawnwilliams shawnwilliams is offline
Re: Best Exhaust?
get a custom cat-back exhaust. Will give the max power to your car. Can find them on any place that sells mx-6 parts
93 FORD PROBE GT
JDM manifold ported match
65mm TB
Unorthodox Underdrive Pulley
Hotshot headers
3' Exhaust all the way
No cat
Cold air intake
K&N air filter
Short throw shifter
Eibach lowering springs
FX Design Body Kit
B&M Short Shifter
Stage 3 Clutch
MX-3 Flywheel
Performace Wires and Plugs
Synthetics
Performance Rad and fan
Mild Weight Reduction
Coming this week:
Performance Heads and Cams
3 angle head job
Why does everyone have to piss on Ford.
Old 07-12-2005, 07:56 AM
Re: Best Exhaust?
Thanks for the reply man. Do you think a 2.5" would be big enough or should I go with a three. Also What muffler would you recomend that would give as little resistance as posible?
Old 07-12-2005, 08:49 AM
mx3man's Avatar
mx3man mx3man is offline
Send a message via MSN to mx3man
Re: Best Exhaust?
2.5" is MORE than enough
Old 07-12-2005, 10:50 AM
Re: Best Exhaust?
Im looking at a monza 2.5"
any one have a clue how it sounds / perfoms ?
Old 07-12-2005, 03:14 PM
mx3man's Avatar
Re: Best Exhaust?
sounds like shit and rusts easier over time. I would suggest get one cutom made by a good exhaust shop in your area. Often it costs less as well.
thats just the hype I've heard. A buddy of mine had it and he HATED the sound. i find that exhaust is a very touchy subject. Everyone has different tastes
Old 07-12-2005, 07:52 PM
Re: Best Exhaust?
I found a good exhuast for a probe of the same year and same engine. I understand that the cars are very similar would their be any diffrence in the exhausts between the two and how dificult would it be to use.
Old 08-20-2005, 05:27 PM
96probegt's Avatar
96probegt 96probegt is offline
Re: Best Exhaust?
on my car i ran 2.25 in to a magnaflo exhaust it sounds real nice
Old 09-16-2005, 10:41 PM
Kyelek Kyelek is offline
Remember that the diameter of the pipe isn't the only thing to consider. Think about how this change will affect your backpressure. Some backpressure is a good thing at low rpm. Consider a two stage muffler to provide low RPM backpressure and less restriction at a higher RPM.
