Go Back   Automotive Forums Car Chat > Mercury > Sable
Old 07-11-2005, 06:02 PM
rhalm24 rhalm24 is offline
Send a message via MSN to rhalm24 Send a message via Yahoo to rhalm24
Question 97 mercury sable
i have a 97 mercury sable and the chek engine light is on so i but the test on cam back cam sensor is bad but i cant find the cam sensor so if some one can help me locate the cam sensor i would appericiate it 3.0 v6 overhead valve
Old 07-13-2005, 01:29 AM
drdisque's Avatar
drdisque drdisque is offline
Send a message via AIM to drdisque
Re: 97 mercury sable
what engine?
Dr. Disque -
Current cars:
2008 BMW 135i M-Sport
2011 Mazda2 Touring
Past cars:
2007 Mazda 6S 5-door MT
1999 Ford Taurus SE Duratec
Old 07-13-2005, 05:46 PM
Tanasi Tanasi is offline
I had the same problem a few months ago. It's located on the front of the engine (end with the belts). It's located on a stunted distributor shaft. The sensor came apart on mine and the sensor and shaft had to be replaced and a used one was nearly as much as a new one. My mechanic said he could replace it but he didn't have the correct computer to align it, so I had to take it the dealer. $537 later I the check-engine light was out, right until the next morning and then another problem reared it's ugly head. You might find someone that works on a lot of Ford's and they might have the correct computer diag. and that might save you a little money. Good luck.
Old 07-19-2005, 07:37 PM
nope tore the hole left side down not there just the crank sensor was all i found
