Old 07-11-2005, 04:47 PM
unicyclemidget11 unicyclemidget11 is offline
how do i adjust the idle?
my car idles a bit low. how can i increase the idle of it? isnt there a screw or something?
Old 07-11-2005, 07:33 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: how do i adjust the idle?
yes, there's a screw at the throttle body. i would assume clockwise decreases, counter-clockwise increases idle (righty tighty, lefty loosey)...but not positive. i'm sure someone else will chime in.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 07-12-2005, 01:14 PM
StealthModifier StealthModifier is offline
yea, cept opposite,,, counter clockwise increases, clockwise decreases.
Old 07-12-2005, 04:19 PM
privatebean privatebean is offline
Send a message via AIM to privatebean
while the topic is fresh...
what is a good idle speed? Mine used to idle between 900 and 1k rpm, after i installed an open air filter and replaced the stock intake pipe it has dropped down between 800 and 900 rpm. Does that sound like a normal thing to happen when adding an open air filter on an N/A?
The change in idle speed hasn't really affected much, but it does dip a little lower then it used to, esp now in the summer when i come to a stop with the AC on.
Old 07-12-2005, 05:38 PM
Linebckr49's Avatar
service manual says curb idle should be 700 +/- 100rpm
93 3000GT base
Old 07-12-2005, 05:39 PM
Wischmaster's Avatar
Wischmaster Wischmaster is offline
Is this screw on the top of the TB or under it? I can't seem to see one below it... unless I'm missing the obvious.
Old 07-12-2005, 05:47 PM
Gateway's Avatar
Gateway Gateway is offline
it's on the top, to the left of it. it will be recessed inside the throttle body
'92 3000GT VR4
Current Mods:
K&N FIPK
RPS Streetmax clutch
Rebuilt tranny
Free Boost Mod
Maximal Performance Solid Motor Mounts
Pictures and Videos of my car
Got a question about your auto insurance? I'm an insurance agent, ask away.
Old 07-13-2005, 06:54 AM
Zeiss's Avatar
Zeiss Zeiss is offline
my idle is at like 750
Bye V8...
Old 07-13-2005, 11:17 AM
i was wondering because whenever i drive my car for like 10 mins or so i notice when i stop somewhere my car idles like at 750 and my oil light starts to flicker. faintly at first, but then it gets more noticeable. also when i get on it a few times i notice itll flicker and sometimes stay on when i come to a stop. is it because of my bov? its an open to atmosphere bov. would increasing my idle solve this?
Old 07-13-2005, 11:44 AM
Linebckr49's Avatar
your OIL light flickers? are you sure its the oil light? what does it look like?
93 3000GT base
Old 07-13-2005, 04:07 PM
a little genie bottle with a little drop coming out. (lol) its red
Old 07-13-2005, 08:00 PM
Hotshot8792 Hotshot8792 is offline
open blow off valve has nothing to do with oil. Check your oil level and see where it stands. If you notice that your oil level is going down slowly, then its flickering because you have an oil leak somewhere. If your oil level is staying the same, then it could be your oil pressure sensor is faulty or some other electrical problem.
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
Old 07-13-2005, 08:52 PM
Idle should be 750. Thats what I saw in a mitsubishi book.
Old 07-14-2005, 12:01 AM
could it be that im running 5w-50 synthetic oil? is it too thin? its been like 75-95degrees during the time this has happend. too thin of oil so not enough pressure?
