Old 07-11-2005, 03:24 PM
JOHNDHALL JOHNDHALL is offline
Park neutral switch 95 Tahoe
HI I’m John and I need the wiring schematic for the park neutral switch on the side of a 95 Tahoe transmission I need it for the entire switch not just for the starting circuit Thanks
Old 07-11-2005, 03:27 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Park neutral switch 95 Tahoe
You sure you got the right forum?
You have a S-10 tahoe or the full size?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 07-12-2005, 08:50 PM
I’m using the 5.7L engine, transmission, computer and harness from a 95 Tahoe in my 94 S-Jimmy 4x4. The transmission has a park neutral switch on the side. Some of the wires from this switch go to the ECM some to the instrument panel and to a plug in the engine compartment. I’m trying to figure out if the transmission will work with my 94 S-Jimmy’s wiring harness if I just eliminate the switch. So I need a wiring schematic
Old 07-13-2005, 12:50 AM
BlazerLT's Avatar
AF -Advisor
If it came from a 95 tahoe, chances are it is OBDII.
Two different computer systems.
Old 07-13-2005, 08:19 AM
No it is the same ECM
Old 07-13-2005, 03:40 PM
BlazerLT's Avatar
AF -Advisor
Is it OBDI or OBDII?
