Old 07-11-2005, 03:11 PM
flyinpoons flyinpoons is offline
1995 GA Turn signal problem diagnostic help needed
I need some advice on a turn signal issue. The turn signals on my fiance's 1995 GA do not work. They worked until 2 days ago, but now do nothing at all. When the turn signal is used, nothing happens, either outside, or inside the car. The arrow lights on the dash do not light up at all, nor do the actual turn lamps outside the car. I checked the fuse, which is fine, so thought it might be the flasher, as the hazard lights do not work either, but a mechanic told my fiance' that if the flasher was bad, the lights on the dash would light, but not flash. I am not sure about this, so I figured asking here might get me the answer I need, any help would be greatly apreciated.
Old 07-11-2005, 09:29 PM
catback23 catback23 is offline
Re: 1995 GA Turn signal problem diagnostic help needed
It depends on how the flasher breaks, they're relatively cheap so worth a try unless you can borrow one which would be better. Your hazard lights work yes? If not your problem is probably not the flasher because I believe the hazard lights have their own flasher on these GA's.
Old 07-11-2005, 10:08 PM
Re: Re: 1995 GA Turn signal problem diagnostic help needed
The flasher does not work, but it was not working long before this problem started.
Old 07-13-2005, 01:24 PM
fixed, thanks for all the input.
