Old 07-11-2005, 02:57 PM
ewbandit2 ewbandit2 is offline
Send a message via AIM to ewbandit2 Send a message via Yahoo to ewbandit2
Major A/C problems
Hi
I know very little about working on cars. On my blazer the a/c went out about a year ago. Got it recharged worked good for a couple of months and then back to hot heat. Got it recharged and checked for leaks. No leaks were found and the same thing happen after a couple of months it went back to hot air not cold. Everything works but the cold air. Some one said maybe fuses, but they were checking and all were good. Any ideas or anything, please?
Eddie W.
Old 07-11-2005, 03:08 PM
blazee's Avatar
blazee blazee is offline
Problem?
Re: Major A/C problems
Sounds like an extremely slow leak. Check your pressure, if it is low again you will have to get the leak fixed before it will work properly.
Old 07-11-2005, 03:22 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
You have a leak, ask them to add UV dye to the fluid when recharging it.
They can then use a blacklight to see the leak in the dark.
1995 Factory Blazer Service Manual for sale, PM if interested.
