Tail Light Problems
New to the forum, so Hello All.
I have a 99 Tahoe with 2 back doors. The blinkers has quit working. A few weeks ago the right blinker was double timing, which used to meant the bulb had burned out. I pulled the light assemblly out, checked the bulb, but it hadn't burned out. swapped bulbs and all 3 bulbs worked in any slot, except the blinker plug. i even changed the light assmebly, and it didn't solve the problem. I eventually found that the copper contacts between the body & the door had to be cleaned. Now, both sides have started doing the same thing. the running lights burn, the brake lights burn, but the blinkers don't blink. i have checked all the fuses, new bulbs, plugs/connections, everything that i know to do. what else is there? is there another plug along the frame under the body that i haven't found? or another plug inside the body besides the on plugging into the lamp assmebly plate? any help would be great. i am at a loss, and a ticket waiting to happen.
thanks.
