Change Oil light in 00 GT
how did I reset this bastard? I had the oil changed a few weeks ago and this light on my dash keeps coming on. I've tried pumping the gas 5 times prior to starting the engine with key turned to on position, but that doesn't work. it's annoying, please help.
thanks in advance |
i thought it was press the gas 3 times within 5 seconds, and that method worked on my 99 GT. other than that, i have no idea how to.
Re: Change Oil light in 00 GT
If you have a GP with a Digital Information Center (DIC) the procedure is different. ![]() Thrasher CAI, DHP v1.0 PCM, 3.25 SC pulley, CAIT GMAF, Hi-Flow CAT, u-bend delete, 160 TS, ZZP Stage 1 TB, TB spacer, MSD 8.5mm wires, Autolite 104s, Goodyear Gatorback Serp. & SC Belt, Nitto NT555R Drag Radials
2001 Grand Prix SE 3.1 - Someone elses problem now! 95 Grand Marquis - Will outlive all of them! 97 F-150 2004 Toyota Avalon |
Re: Re: Change Oil light in 00 GT
![]() ![]() Thrasher CAI, DHP v1.0 PCM, 3.25 SC pulley, CAIT GMAF, Hi-Flow CAT, u-bend delete, 160 TS, ZZP Stage 1 TB, TB spacer, MSD 8.5mm wires, Autolite 104s, Goodyear Gatorback Serp. & SC Belt, Nitto NT555R Drag Radials
Re: Re: Re: Change Oil light in 00 GT
I thought they all had DIC's. . . |
Re: Re: Re: Re: Change Oil light in 00 GT
Be cool?
Thanx it went over 100 here today. Two hours to Beer. . . |
thanks guys. I'll try it again.
No DIC. |
got it. it should have been worded differently.
pump the gas three times slowly within five seconds, start the ignition and THEN the light will blink meaning it is resetting. thanks again guys |
