Old 07-11-2005, 01:04 PM
L|_|da L|_|da is offline
Send a message via AIM to L|_|da
Ported Box?
I recently did a dual RE12 setup, NX400 amp, 200W, in a 3.2CUFT enclosure, sealed. im wondering if a ported box will make much difference, and if it will, how big to get that difference? and how hard is porting/tuning it? and help if much apreciated.
Old 07-11-2005, 09:10 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: Ported Box?
Well it will definitely make a big difference, the question is if you like that difference. To put it simply, you'll gain a lot of low end, it will be like putting in a 6-10dB bass boost at whatever frequency you tune the box at, and setting a very steep highpass filter about a half an octave below that, some people like it, some don't. I'm one that doesn't, because to me it sounds unnatural and....like crap. Ported boxes have their place, but that place is not in a car.
[/soapbox]
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 07-12-2005, 08:35 AM
Re: Ported Box?
so basically, they cut down the RANGE of sound, but that range is LOUDER?
Old 07-12-2005, 01:03 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
yea, pretty much. And you have to use a steep filter below the port frequency because at frequencies much below that the box will look to the speaker as if it has a big hole in it (whick it does), and speaker will be unloaded ... similiar to free air.
Old 07-12-2005, 03:05 PM
Re: Ported Box?
steep filter? like fro mthe amp?
so below the tuned freq it sounds nasty / doesnt sound
Old 07-12-2005, 06:40 PM
sr20de4evr's Avatar
Re: Ported Box?
When the sub starts to unload (about a half an octave below the tuning frequency), you'll have virtually no audible output and the sub's cone will be moving a LOT for a given amount of power, which means it will bottom out very easily. You need to set a highpass filter (aka subsonic filter) around the tuning frequency to keep this from happening.
'01 Black Sentra SE
'05 Silver WRX STi
Old 07-13-2005, 11:39 AM
Re: Ported Box?
ah, well do i have to get a new amp, or some sort of addon for the subsonic filter? the amp thats installed is an NX400. if i do what do i need, how would i go about setting up the sub filter?
Old 07-13-2005, 01:02 PM
Audio Guy
many eq's have them ..... they are real easy to set
Old 07-13-2005, 06:12 PM
CBFryman's Avatar
CBFryman CBFryman is offline
Banned
Send a message via AIM to CBFryman Send a message via Yahoo to CBFryman
Re: Ported Box?
SR20 is just an SQueer...
you dont have to worry about the roll off of ported enclosures in most daily apps because you will turn aroudn 30Hz generally and most music doesnt even have frequincies below 30Hz... and with the lower tunings your responce curve, though not as flat as sealed, isnt as peaky as they are telling you.
Old 07-14-2005, 12:27 AM
Jeremy86 Jeremy86 is offline
Send a message via AIM to Jeremy86
Re: Ported Box?
I had a sealed box in my car and I thought that it was loud. I built my first ported box and it was amazing. I don't want to sound push offish or showoffish, but I talk to competitors and street beaters alike, and going from sealed to ported gives a 3db increase, which is about twice as loud as it was. Not trying to bash Sr20 at all, but basically a ported box, yes it seems to be louder at a certain frequency, I tune my boxes from 30-35hz which is really deep sounding. The thing with sealed boxes is it gives a flat response in all bass frequencies, which in some cases is better. Ported boxes I've always liked, you have to build the enclosure to what the sub likes, you can't expect a prefabricated one to sound good for your sub. Possible, but not probably the 'magic' box. It's not hard doing a ported box, it's more hard figuring out port length, how much port area you want, and the displacements of the port and sub. Using your TS parameters, you can design a box that your subs will like. If you think you're interested in it, let me know, I'd be glad to try to help.
Aka 93 Cutty
Working on my next project: A 1986 Honda CRX. Little beater with lots of engine
Car Audio Freak
http://www.sounddomain.com/ride/613185
Old 07-14-2005, 08:01 AM
sr20de4evr's Avatar
Re: Re: Ported Box?
anechoic it's not, but when you stick it in a car it is
'01 Black Sentra SE
'05 Silver WRX STi
Old 07-14-2005, 01:04 PM
Audio Guy
the problems is, the higher the order the more picky the box is to mistakes in volume and port calculations .... and that doesn't take in the cars response either
Old 07-14-2005, 01:11 PM
Re: Ported Box?
Most cars if you tune around 30s will sound good. You need to worry about the resonant frequency in your car if you are looking to burp and compete. That's my opinion though.
Aka 93 Cutty
Car Audio Freak
Old 07-15-2005, 11:11 AM
Re: Ported Box?
i think ima gonna do this, but not for the RE12s, friend doesnt wan it louder. but i am getting a free 15" Kicker comp not solo baric. so im thinking about a 3-4 cube box, since i have the wood to make it(3/4" MDF) how much port area should i have, and should i use tubes? or square? and how do i calculate the port length?
