Old 07-11-2005, 12:00 PM
Robynruss Robynruss is offline
88 4wd blazer S10 brakes are spongy
I have replaced the front brakes and the wheel cylindars in both back brakes, bled the brakes continually, and still they are spongy! They are at least halfway down before you notice a slowdown and all the way to the floor before you stop. Any ideas? The truck is for a teenager so I can't have any brake problems or its a sure accident! Is there something completely obvious I am missing?
Old 07-11-2005, 12:15 PM
blazee's Avatar
blazee blazee is offline
Problem?
Re: 88 4wd blazer S10 brakes are spongy
Can you pump them up and they hold pressure or do they leak down?
Were they spongy before you worked on the brakes?
Did you bleed them properly? It takes a while to get the air out when parts have been changed.
Bleeding Process
1. Begin at the corner furthest from the driver and proceed in order toward the driver. (Right rear, left rear, right front, left front.) While the actual sequence is not critical to the bleed performance it is easy to remember the sequence as the farthest to the closest. This will also allow the system to be bled in such a way as to minimize the amount of potential cross-contamination between the new and old fluid.
2. Locate the bleeder screw at the rear of the caliper body (or drum brake wheel cylinder.) Remove the rubber cap from the bleeder screw – and don’t lose it!
3. Place the box-end wrench over the bleeder screw. An offset wrench works best – since it allows the most room for movement.
4. Place one end of the clear plastic hose over the nipple of the bleeder screw.
5. Place the other end of the hose into the disposable bottle.
6. Place the bottle for waste fluid on top of the caliper body or drum assembly. Hold the bottle with one hand and grasp the wrench with the other hand.
7. Instruct the assistant to "apply." The assistant should pump the brake pedal three times, hold the pedal down firmly, and respond with "applied." Instruct the assistant not to release the brakes until told to do so.
8. Loosen the bleeder screw with a brief ¼ turn to release fluid into the waste line. The screw only needs to be open for one second or less. (The brake pedal will "fall" to the floor as the bleeder screw is opened. Instruct the assistant in advance not to release the brakes until instructed to do so.)
9. Close the bleeder screw by tightening it gently. Note that one does not need to pull on the wrench with ridiculous force. Usually just a quick tug will do.
10. Instruct the assistant to "release" the brakes. Note: do NOT release the brake pedal while the bleeder screw is open, as this will suck air back into the system!
11. The assistant should respond with "released."
12. Inspect the fluid within the waste line for air bubbles.
13. Continue the bleeding process (steps 11 through 16) until air bubbles are no longer present. Be sure to check the brake fluid level in the reservoir after bleeding each wheel! Add fluid as necessary to keep the level at the MAX marking. (Typically, one repeats this process 5-10 times per wheel when doing a ‘standard’ bleed.)
14. Move systematically toward the driver – right rear, left rear, right front, left front - repeating the bleeding process at each corner. Be sure to keep a watchful eye on the brake fluid reservior! Keep it full!
15. When all four corners have been bled, spray the bleeder screw (and any other parts that were moistened with spilled or dripped brake fluid) with brake cleaner and wipe dry with a clean rag. (Leaving the area clean and dry will make it easier to spot leaks through visual inspection later!) Try to avoid spraying the brake cleaner DIRECTLY on any parts made of rubber or plastic, as the cleaner can make these parts brittle after repeated exposure.
16. Test the brake pedal for a firm feel. (Bleeding the brakes will not necessarily cure a "soft" or "mushy" pedal – since pad taper and compliance elsewhere within the system can contribute to a soft pedal. But the pedal should not be any worse than it was prior to the bleeding procedure!)
17. Be sure to inspect the bleeder screws and other fittings for signs of leakage. Correct as necessary.
18. Properly dispose of the used waste fluid as you would dispose of used motor oil. Important: used brake fluid should NEVER be poured back into the master cylinder reservoir!
Old 07-13-2005, 02:01 PM
I guess I forgot to mention that the brakes feel fine (firm and hold well) when the truck is off, it is not until you turn on the ignition that the brakes get soft. They have been bled (properly) by at least 3 people now, and while they hold fine in the off position, it is really hard to tell how they are holding while the truck is on since they pretty much go to the floor anyway. Sorry, the on/off info was probably pretty important, but it just slipped my mind.
Thanks
Old 07-13-2005, 02:30 PM
s10blazerman4x4's Avatar
s10blazerman4x4 s10blazerman4x4 is offline
Send a message via AIM to s10blazerman4x4
combination valve under the master cylinder
have you replaced that
1991 Chevy S-10 Blazer 5.7 V8 RIP
1999 Chevy Blazer 2dr 4.3
