Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 07-11-2005, 09:28 AM
CharlieFoxtrot CharlieFoxtrot is offline
2002 Aurora, water leak in rear seat area
My wife's 2002 Aurora (13500 mi) has wet carpet in the driver's side rear. We've had it about 6 weeks and this is the first time we've noticed water. Then again, it's only the beginning of hurricane season...
I searched the board for water leak problems and didn't find any that involved the interior. Anyone ever have a problem like this?
What else can I tell you about the car? Never wrecked, no sunroof, no modifications, no visible wear or damage to weatherstrips.
thanks
kevin
2002 Aurora 3.5
Old 08-14-2005, 11:34 AM
petersi petersi is offline
Re: 2002 Aurora, water leak in rear seat area
I think I have the same problem with my 3.5, 2001. It apears that the water is a condensation coming from the AC system. My carpet is wet in front of the front passenger seat. I couldn't figure out how to fix it. Were you succesfull?
Peter
Old 08-14-2005, 03:49 PM
Re: Re: 2002 Aurora, water leak in rear seat area
Mine was wet in the driver's side rear. That's probably not an AC problem. Hasn't happened since I posted.
Good luck with yours.
kevin
2002 Aurora 3.5
Old 11-02-2006, 07:42 PM
tmcnall tmcnall is offline
same thing with my 2001 - this will be a pain to fix.
It's definately NOT A/C condensate....waaaaaay too much water
rusted a clip splicing serial data wire brown and brn/white in harness and took out all power windos and locks except driver door. Had to solder and tape.
Old 02-28-2007, 01:21 PM
ksierens ksierens is offline
I am also having the same problem with my 2001. The first time I noticed this, the drivers rear floor was really soaked, and drivers front also. I blamed my wife for leaving down the window one night that it rained, but that was not the case. I blew out the sunroof overflow tubes, and looked under the cowl cover, but have still not found anything. I also pulled back the carpet but did not see anything that might be causing the leak. What makes it worse is that the padding under the carpet is like a sponge so it really holds the water.
Old 02-28-2007, 03:50 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Sorry but I recommend that you start a thread addressing your issue. This thread is too old and we prefer they are not resurrected. Thread has been closed.
Timeslip 08/12/06
AF Community Guidelines
Closed Thread
