Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 07-11-2005, 09:10 AM
craigyd71 craigyd71 is offline
Tailgate won't open
Hey all,
I have a 97 Grand Cherokee Limited For some reason the tailgate wont open, when unlocked the door wiggles a bit but won't open. The rear window does open without any problems. Any Idea how I can open this and find out what the problem is. I found this when I went to change a broken brake light bulb. Any help would be greatly appreciated.
Thanks
Craigyd
Old 07-11-2005, 09:19 AM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
Re: Tailgate won't open
Try pushing in on the door, pulling on the handle and lifting open. If that don't work try to give a few hard tap with a closed fist next to the handle of the liftgate.
well when you get it open spray the locking mechanism (in the liftgate) down with some WD-40 or PB Blaster.
Old 09-05-2005, 07:37 PM
Airman Kelley Airman Kelley is offline
rear door
You need to remove the screws on the top of the panel that covers the lower portion of the door. Pull the plastic panel as far fowward as you can and look in to see what I am describing. There is a cable with a swedge that gets pulled towards the drivers side when you lift the handle. A plastic clip retains the swedge. The plastic clip has "unclippped" itself and the swedge doesn't have a retaining mechanism.
I superglued mine back together. youll scratch your arm up, but with practice, I could snap mine back in place in the dark, until I just superglued the bastard.
