Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '71-'87 Civic | CRX
Old 04-24-2002, 06:38 PM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
rear bracket mount
Hey sup guys. I just bolted my b16 today and the rear bracket was a pain. I can't get it to line up with the tranny bolt! So i thought i'd take it off and bolt the motor on first then put the bracket on later. I tried it but it seems like i have to take out the motor again Is there any other way to do install it without takin out my motor??
Old 04-24-2002, 09:40 PM
91zc 91zc is offline
Yeah, it is a real pain in the arse. Have the bracket loosely bolted to the block and trans and then try dropping it in. I had a friend and my brother help me line the damn thing up. It took us a couple tries but we finally got it.
91 civic 4dr
b16a
14.8@94
Old 04-25-2002, 07:14 AM
ricodemus ricodemus is offline
yeah, we dropped the motor in loosely and put a jack underneath it (with a piece of mdf in between) so we could control the motor a little better and get the bracket on.
I'm a lonely male who'll settle for any phony in a ponytail - MCPB
The b16 is in and running strong
Old 04-25-2002, 08:48 AM
mellowboy's Avatar
Shit so i have to take out the motor again..damn!
Old 04-25-2002, 12:06 PM
Dont take it out, leave it in the engine bay. Assuming its still suspended in by the cherry picker, use a jack from underneath to make vertical adjustments. With 2 people it shouldnt be that bad. How is your front mount bracket fitting? Your kit use it? mine didnt and we had to cut it out.
Old 04-25-2002, 02:53 PM
mellowboy's Avatar
Yeh but NOW my friend told me there wont be enough room for me to plug the wires and wiring up the v-tec. He told me i should've done that before i bolt it on? Oh well. About the front mount.... no i didn't put it on yet but it seems like it will fit with no problem. I just have to unbend the front crossmember bracket cause its kinda dented in when i was installing my motor.
Old 04-25-2002, 03:28 PM
you should have prepared the wiring harness before you put it on, just because most of the plugs are in the back. The vtec solenoid itself is right in front of you, so that isn't hard to wire. It's the oil pressure sensor and knock sensor you need to worry about. I'm assuming you have an si.
Old 04-25-2002, 04:25 PM
Phatwhippin_CRX Phatwhippin_CRX is offline
Send a message via ICQ to Phatwhippin_CRX Send a message via AIM to Phatwhippin_CRX Send a message via Yahoo to Phatwhippin_CRX
ahhhhh.......... i love having a lift
1989 DOHC VTEC CRX Si
C'mon, it's only a Honduh...can't be fast!
I AM the Anti-Rice!
Swap info, Turbo tech, and naked chicks!
Old 04-25-2002, 05:34 PM
mellowboy's Avatar
Yeh i do have an si. Yeh i'm gonna contact some dude that'll help me do my swap. He's done like 6 of them so far. So i hope he can help me cause all my friends bailed out on me...i'm all alone now
Old 12-03-2004, 12:11 AM
mugenEG6 mugenEG6 is offline
rear mount
Just replying to the previous statements about the rear mount.. On mine i just jammed it in there.. i had to take the frame mount off and put it on the bracket mount but i got it in.. however it dint line up with the bolts on the frame ne more but.. Thats not the point haha lol i managed to pound it in
but only if that frame mount is off
its easyer when u ahve the motor in the car if u install the motor With out the rear mount or frame mount then add them on after the motor is in
i have a civic it may be different on Integras but i have to modifie now.. one of my 3 mounts on a gsr mount.. 2 an si mount and D a DX mount
so the GSR mount is the only one that will line up with the motor and the frame. but i have to notch it.. all 4 corners
and it has to be cut an inch
and new holes drilled then notch it aboutn and inch in the bottom takeing most of the bottome box pice out so the frame moutn can fit in.. another possible problem would be the frame mount is to wide for the Gsr mount simply take out the part that is in the way of the mount.. there will be a weakening in structure but that mount dosnt nessisarly support the motor.. it just keeps it from twisting as much
It makes it a little easyer than the alternative.. wich is redrill and relocate the holes on the crosmember.. wich on my car appeared to be impossible since the crossmember is formed around the mount so u move it over.. one bolt bolds in the air and the other to are uneven ebcause of the indentation from where the factory mount location
This is all i can say for mounting for now
Rear suspension sound: Strut mounts? olopezm Grand Prix 27 12-29-2010 11:51 AM
97 riv missing bolts for lower bracket mounting to block srussell1027 Riviera 0 01-13-2010 01:07 PM
Rear Bracket below bumper near exhaust densmustang RX300/RX330/Harrier 0 11-20-2009 11:52 AM
Rear cab mount bracket rusted out joslinm Problem Diagnosis 1 01-27-2008 09:13 AM
rear motor mount brackets joey h. Engineering/ Technical 2 10-09-2003 09:59 AM
