Go Back   Automotive Forums Car Chat > Lincoln > Mark VIII
Old 07-11-2005, 03:32 AM
OldRelayer OldRelayer is offline
Right Door Ajar on 98 Mark
We have an intermitten problem with the the car thinking the right door is open. This is a problem because the interior lights stay on and of course that would lead to a dead battery. Happened again last night but this time I couldn't get it to go away, so I took out the fuse for the lights. I don't have any idea whatelse this might affect, the headlights still work, so it may be ok to drive like this, but don't know for sure.
I am guessing this is in the door switch, but I don't really know because over the 5 Marks we have had, the message center can be a bit missleading. First question is, I can't find the door switch, it is the passenger side, can anyone tell me how to locate the switch? If you have anyother ideas on what the problem may be, please let me know.
Thanks
Barry
Old 11-01-2005, 09:31 AM
frankjc frankjc is offline
Mine always says "door ajar" and i have no idea why.
Old 11-13-2005, 08:52 PM
BlackiceLSC BlackiceLSC is offline
Re: Right Door Ajar on 98 Mark
each door has a "sensor" that is actually part of the door latch mechanism itself, inside the door. it doesnt employ the typical "button" like most cars, for the "door ajar" system. This is mainly because the air ride system depends on the door actuation for "vent/parked" cycling.
The actual test-fix is to use WD-40, and liberally spray into the door's latch mechanism. Use it liberally. then open/close the door several times, normally.
That should pretty much take care of it. If you continue to have any problems, the switch itself may be worn, and will require a new one.
any other questions, feel free to ask me.
Old 11-14-2005, 09:31 AM
Thanks, I hit it with some WD40...so far so good.
Old 11-15-2005, 09:11 AM
Hey blackice, I saw your article on coil spring conversion over at lincolnvscadillac... pretty cool. I have been having air suspension issues, and am thinking about converting to coils.
Old 11-15-2005, 10:20 PM
that is an old article. I have completely replaced that set up with a new set up from a far superior vendor.
if you so wish to go that route, let me know...I have the "hook up" for you.
I also have a new tech article, with improved details in lincolnsonline.
here's THAT link.
let me know if I can be of any more help.
Old 11-15-2005, 10:50 PM
Cool! That article is even better....nice pics, and excellent explaination of each step.
I am thinking the conversion is the way to go...what is the "hook up"?
Old 11-15-2005, 11:55 PM
I dont want to hi-jack this thread, so I'll send you the info via priate message, ok?
Thanks for the props, BTW
Old 11-16-2005, 07:17 AM
OK..sounds good.
You're welcome...you did a great job with that.
