Old 07-11-2005, 12:59 AM
proud_924s_owner's Avatar
proud_924s_owner proud_924s_owner is offline
Send a message via AIM to proud_924s_owner Send a message via MSN to proud_924s_owner Send a message via Yahoo to proud_924s_owner
Question overheating problem
ok, my friend has a 1992 accord and it overheats at low speeds. everything appears alright and the motor makes no noises to make me suspect anything major... im thinking theres a blockage somewhere in the cooling system, a stuck thermostat, or perhaps a sensor not functioning properly. it was suggested by many people to be a head gasket however, theres no water out the tail pipe and no oil in the coolant or coolant in the crankcase. there is no noise in the water pump and the cooling fans work and turn on by themselves when the motor starts to get on the warm side.... please help. im trying to save my friend a few thousand dollars and weeks of hassels with a mechanic. thank you.
1966 ford mustang 302 C-4 coupe burgundy/rust not running current project car 300,000 miles
1987 porsche 924s 5-speed red wrecked
1987 porsche 924s 5-speed white gutted interior, computer chip, throttle cam, KnN air filter, blown clutch, 225,000 miles..... future 944 spec race car
02 SVT focus ZX3 touring daily driver
Old 07-11-2005, 11:19 AM
mpumas mpumas is offline
Re: overheating problem
Do the cheap things first like replace the thermostat. The next thing would be to do a radiator descaling and backflush. The best way to do the backflush is with the radiator removed. You can also check the airconditioner condenser to see if the cooling fins qre clogged with bugs and can also reverse blow/wash it if the radiator is removed. Check the radiator fins so see if they are clogged and reverse blow to clean. All this can be done rather cheaply. If this doesn't fix the problem get back to us. If it does fix it, also get back to us.
