Old 07-10-2005, 11:55 PM
Jos4DCivic's Avatar
Jos4DCivic Jos4DCivic is offline
Send a message via AIM to Jos4DCivic
ignition switch
Ive got a little problem. i Lost my Fuckin key to my White hatch. i was gonna switch over ignition switch from rex but cant get hatch one off. took screws off and nuttin. any special to get off? i took door lock off and was gonna go get a Key made but figured might try this and save some money for my stupidity.old one bad as it is any how.
91 Hatch SI
Heart of my Baby - DOHC ZC - Si tranny - PG7
Finally painted!!!
Old 07-11-2005, 12:48 AM
BullShifter's Avatar
Re: ignition switch
Turn the ignition switch to l
use a small allen wrench to push the pin in (small hole on top of lock cylinder)
Pull cylinder out
Old 07-11-2005, 01:19 AM
Jos4DCivic's Avatar
no key to turn to 1 position. me and loosing keys . gonna hang it on a chain around my neck from now on.
91 Hatch SI
Finally painted!!!
Old 07-11-2005, 02:21 PM
Hybrid1990crx's Avatar
Re: ignition switch
just change out the entire ignition set up. all you have to do is cut a slut in each of the bolts so you can get them out with a screwdriver and then unclip it from the harness under the dash, and put the new one back in, simple as that.
Old 07-11-2005, 06:51 PM
sofast's Avatar
sofast sofast is offline
Send a message via AIM to sofast Send a message via MSN to sofast Send a message via Yahoo to sofast
Take your title and registration to any honda dealer and they can make or get you a key from the VIN #. I have had to do it on many of my hondas. I believe its like $12
Old 07-12-2005, 01:43 AM
Jos4DCivic's Avatar
switch over whole thing like hybrid mentioned. worked perfect. hardest part was getting lock aligned with plastic
thnx
91 Hatch SI
Finally painted!!!
Old 07-12-2005, 04:36 PM
Re: ignition switch
always happy to help
