Old 07-10-2005, 09:31 PM
SteveK2003 SteveK2003 is offline
Send a message via AIM to SteveK2003 Send a message via Yahoo to SteveK2003
How long have I got to re-coat (Tamiya lacquers)
I got three mist coats and two wet coats down tonight, but I can't add more wet coats until tomorrow morning. Is that OK?
I was doing the coats every 15-30 minutes per recommendations, didn't know if I needed to stick with that method or not.
Old 07-11-2005, 12:10 AM
JTRACING's Avatar
JTRACING JTRACING is offline
J.E.T.
with lacquer, it doesnt matter how long you wait. 5 mins or 5 days, you can add paint anytime.
Old 07-11-2005, 07:01 AM
Re: How long have I got to re-coat (Tamiya lacquers)
OK, thanks. I laid another coat on this morning befoe work.
I noticed a few worry spots: A couple tiny 'bubbles' almost on one side of he car, and some uneven spots in another.
I'll tell you, probably the last time I use Tamiya lacquer from the can: I'll just decant the stuff and use my airbrush from now on. Way too much over spray, paint going everything, small areas don't get enough paint, etc.
Old 07-11-2005, 12:25 PM
g00eY's Avatar
g00eY g00eY is offline
use some Duplicolor. lol. i had bubbles on my Supra but i wasn't worried cuz that was my first paintjob. they ended up in the panel lines and whatnot. good luck with the spraying.
Old 07-11-2005, 12:43 PM
Jaymes's Avatar
Jaymes Jaymes is offline
i don't know about you but Duplicolor spray cans are much worse than Tamiya spray cans. They don't propel as strong and the particles are pretty damn rough, so a dedicated sanding job is required.
