Old 07-10-2005, 09:16 PM
ddime2000 ddime2000 is offline
Steering Problems and Check Engine light
New to the site and new to the Grand Prix. Wife and I just bought a 2001 GT 2 weeks ago and today the check engine light came on following a tight U-turn. Since we got the car I have noticed it is nearly impossible to steer when we're not moving. Once the car begins rolling it becomes normal. I already checked the fluid levels and belt tension. They're ok. Anyone have any info that may help me out? Thanks ahead of time.
Old 07-11-2005, 01:05 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Steering Problems and Check Engine light
On the SES/CEL light you should get the PCM computer odb-ii scanned for DTC error codes. Its probably emissions related and has nothing to do with the hard steering but you never know. National auto parts stores like Autozone will normally do it for free if the SES light stays on.
The GP GT and GTP has a variable ratio rack n pinion steering unit. It should be easy at low speeds and then get progressively firmer at higher speeds. The car should not be that hard to steer when not moving. Could be low pressure feeding the rack n pinion unit due to a defective power steering pump.
BTW - Welcome to the GP forum.
Thrasher CAI, DHP v1.0 PCM,
3.25 SC pulley, CAIT GMAF, Hi-Flow CAT,
u-bend delete, 160 TS, ZZP Stage 1 TB,
TB spacer, MSD 8.5mm wires, Autolite 104s,
Goodyear Gatorback Serp. & SC Belt,
Nitto NT555R Drag Radials
Timeslip 08/12/06
AF Community Guidelines
Old 07-17-2005, 02:54 PM
Re: Re: Steering Problems and Check Engine light
[quote=bnaylor3400]On the SES/CEL light you should get the PCM computer odb-ii scanned for DTC error codes. Its probably emissions related and has nothing to do with the hard steering but you never know. National auto parts stores like Autozone will normally do it for free if the SES light stays on.
Thanks! Well the dealership has the car now and they are fixing what ever they find wrong with it at no charge. But no word on what the problem is....
Old 07-17-2005, 03:25 PM
BNaylor's Avatar
Re: Re: Re: Steering Problems and Check Engine light
Thats sound like a good deal. Let us know how it turns out. Good luck!
Timeslip 08/12/06
