Old 07-10-2005, 09:13 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
1992 Civic EX has no EGR?
I heard it doesn't have one? It is true?
I have a pinging problem and I want to see if it could be the cause.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 07-11-2005, 10:51 AM
jcrx jcrx is offline
Send a message via AIM to jcrx
Re: 1992 Civic EX has no EGR?
Nope, only Civic with an EGR in 92-95 is the VX.
Old 07-11-2005, 12:19 PM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
pinging is usually the gas your using. try a higher octane.
Old 07-11-2005, 01:31 PM
snowman2005's Avatar
snowman2005 snowman2005 is offline
Send a message via AIM to snowman2005
but even if he does use higher octane the problem is still ther. check ur timing it might be too advance.
ive got manuals
92-95 civic 96-98 Civic
clicky here clicky here
WTB:92-95 EX/SI cluster w/tach
FS:*NEW* 92-95 civic coupe black floor mats(4). pm me for pics or offers
Old 07-11-2005, 02:51 PM
BlazerLT's Avatar
AF -Advisor
Re: Re: 1992 Civic EX has no EGR?
Been there, no difference.
Old 07-11-2005, 03:01 PM
Kind of a Big Deal
then check your timing like Snow said.
Old 07-11-2005, 03:16 PM
EX compression is not high enough to warrant "high" octane gas. Check you timing, retard you distributor so if it helps. Have you looked at your spark plugs?
Old 07-11-2005, 03:23 PM
BlazerLT's Avatar
AF -Advisor
timing will be set today, I just wanted to see if there was an EGR valve as well.
Plugs were changed to the factory specified colder plug. Made no difference.
All plugs made the same pinging.
Old 07-11-2005, 03:31 PM
I'd say your timing has slipped out then.
Old 07-11-2005, 03:41 PM
BlazerLT's Avatar
AF -Advisor
Yea, my thoughts too, thanks for the info though.
I didn't want to go through all of this and find out it was the EGR valve clogged or something.
Old 07-11-2005, 03:46 PM
Not unless you meant V instead of E X
Old 07-11-2005, 04:52 PM
BlazerLT's Avatar
AF -Advisor
Very true. Thanks dawg, I appreciate the time and effort.
Old 07-14-2005, 02:42 AM
BlazerLT's Avatar
AF -Advisor
Well, the timing is perfect and I back pressure tested the cat and it still pings.
Could this be low fuel pressure brought on by a bad fuel pressure regulator?
Old 07-14-2005, 04:51 AM
Turn your distributor all the way towards the front of the car, retard it all the way. If the pinging goes away, push it back forward, try it, no ping, forward some more, etc.... till it pings then back it off a bit, retighten. That could work, and if it does, it's only a bandaid really.
Check the FPR pressurre should be 280-330 kPa(40-47 psi).
Old 07-14-2005, 11:06 AM
BlazerLT's Avatar
AF -Advisor
Turning it towards the front advances the timing. When timing it we confirmed this.
The timing is set perfectly. Must be a fuel pressure problem.
