Old 07-10-2005, 09:12 PM
volzman volzman is offline
1997 LX a/c 3.0 DOHC
My 97 has the all digital panel. When i hit the max a/c button it dosent change, what could that be.
Old 07-11-2005, 09:39 PM
vicv vicv is offline
Re: 1997 LX a/c 3.0 DOHC
A loose vac line.
Old 07-12-2005, 05:51 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
What doesn't change? The AC indicator doesn't come on on the panel? The air coming out the vents doesn't get cold? The blower doesn't come on? Need more details. What happens if you select "Auto?" What happens if you select the Defrost icon? Does the air to the windshield come out cold?
-Rod
Old 07-13-2005, 09:12 PM
Re: Re: 1997 LX a/c 3.0 DOHC
-Rod
Everything on the display is correct, It used to get a little stronger and colder when i hit the max ac button. Basicaly I dont think the recerculate is working. when i hit the defrost, or auto or floor it all works fine. but the only thin that happens when i hit the max ac button is it says max ac on the screen, but nothing else happens.
Old 07-13-2005, 10:07 PM
shorod's Avatar
SHO No Mo
Re: Re: Re: 1997 LX a/c 3.0 DOHC
I think the previous poster may have been on the right track. You probably have a vacuum line or vacuum actuator issue. I have posted the Ford vacuum troubleshooting table at http://www.members.aol.com/Rod241473...Stuff/EATC.jpg
You might be able to apply vacuum to the proper ports to determine if the actuators are working properly.
-Rod
