99' Blazer Shocks
Has anyone installed the Monroe Reflex shocks on their Blazer. I have heard good things from two differant Mechanics and was thinking about getting them. I have 115K miles on my truck and was told by the dealer that rotates my tires that the factory ones are still fine. I want going to change them before I have the signs of bad shocks. There is a place by me that will install the Monroe Reflex (all 4) for about $250.
Re: 99' Blazer Shocks
Stock shocks are excellent.
1995 Factory Blazer Service Manual for sale, PM if interested. |
Shocks
Yep, sure did (on my old 95 Blazer). They worked really well on road and off (ranch roads and such). I no longer have that car, but those shocks seemed really good to me
Tim
Tim Flowmaster series 50 delta Airraid cold air intake Hypertech computer program everything else is bone stock |
Shocks
Thats a pretty fair price too.
I have them on the front on my blazer seem to be pretty good.
1991 Chevy S-10 Blazer 5.7 V8 RIP 1999 Chevy Blazer 2dr 4.3 |
I run those right now. 25 a piece with free installation at NTB (otherwise I would have just installed them myself). I've been pretty happy with them.
![]() ![]() 95 s10 Blazer, EGR Mod, ZQ8 Steering box mod, 99 Center console shifter mod and more... See everything at www.pghconsulting.net/teal |
I am not a mechanic by any means, but i have more than just common knowledge... but how can you tell if the stock shocks are still good? i have 150k miles and its a 97 4X4 but at Tuffy getting an Oil Change done, the mechanic stating it was "just his job" to tell me these things, said i could use new shocks and that they are eating away at the tire? i thought.. well yeah i COULD use new everything, but i thought i would check here to see if he might have been just trying to sell.
ALSO, how often is a tranny flush/fluid replacement necessary? he said the fluid was reddish brown and looked like it hadnt been flushed before. this is probably a must-do soon, right? Thanks for all the help.. |
On my 91 blazer I had uneven tire wear on my front tires. The inside edges of the tires were wearing faster than the rest. I thought this was an alignment problem but the mechanic said I needed new front shocks. He installed new shocks rotated the tires and the problem was fixed.
if your at 150k a tranny flush is a good thing... you know your shocks are bad because you will bounce several times instead of just once or twice on the big bumps
I think I found the knocking noise in my front end. It seems to be coming from one of the new shocks I had a local dealer install (Monroe Reflex). If I hold my hand on the shock body and move the car up and down a little I get the knocking sound and feel it very strongly in the shock. I then noticed that the installer dented and scraped up the shock tube trying to get it into place. Are there things inside that move up and down that can be hitting the dent which cause the clunk or knocking sound and feel???
When I called the repair shop they appologized for the lack of quality and promised to look at it first thing in the morning. |
Yea, it would cause it.
Yep, a dent in the tube can restrict movement of the piston inside of it. Get it checked ASAP and see if they will cover the cost of the new shock too. Having installed plenty of my own, it's not hard to do and there is no excuse to damage one in the process of installation. Gas charged shocks can be a little tougher to install. Once the band over them is released, they slowly expand with internal pressure - and once extended, impossible to muscle into place. Usually one mounts the bottom of the shock, cuts the band and guides the upper mount into place as it lifts itself up into place. He may have gotten into a little trouble if he did not realize this until it was too late and had to "beat on it" to get it to go in. As I said, no excuse, indeed have them look at the work and replace the part on their dime for the damage.
