Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 07-10-2005, 11:16 AM
cutlasskenny's Avatar
cutlasskenny cutlasskenny is offline
Acts like brakes are sticking
I have a 95 Jimmy SLT, my problem is after driving a while, hour or so, sometimes when i slow down for red light or whatever it will act like the brakes are sticking. i figured a caliper was sticking and would replace it soon, but yesterday i noticed somthing. i do have 4X4 (which doesnt work and narrowed down tothe actuator or encoder motor im guessing) every time it has happened my 4 x4 light switches to 4lo by itself, then within the next few stops it wont go, and yesterday i heard a *clink* from under truck and the light switched from 4lo to 2hi and the truck went on just fine...anyone heard of this?
Old 07-10-2005, 12:27 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Acts like brakes are sticking
You were in 4x4 and you probably didn't know it.
You best be fixing your 4x4 system ASAP before you wear out your front end.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 07-11-2005, 10:31 AM
the front axles wont engage but, when correctly switched into 4lo it will go into low gearing just in the rear wheels. it did do the same thing again yesterday and im noticing more the 4lo light will switch on and off by itself right around the time i have the problem...i can floor the accelerator, engine seems fine it just barely goes for about 10 seconds or so
Old 07-11-2005, 02:50 PM
BlazerLT's Avatar
AF -Advisor
Re: Re: Acts like brakes are sticking
You have a problem with your transfer case encoder motor of the vacuum switch for the transfer case.
Old 07-11-2005, 07:52 PM
That is whats wring with 4 wheel drive, but that also causes my other problem also? i guess it makes sense if it is with either the gears or computer
Old 07-11-2005, 10:39 PM
BlazerLT's Avatar
AF -Advisor
That is probably why it is sluggish off the line.
The engine rpms go up until the leaking vac hose going to the diaphram get enough vac to offset the leaking loss and then the transfer case will then properly get into gear.
I would check the vacuum line going to the vacuum actuator and the actuator first.
Old 07-13-2005, 05:33 PM
Would this also cause the transmission to act funny? driving today after getting off the highway it wouildnt shift out of 2nd, then after parking and leaving again it would go to 3rd but not 4th and would shift between 3rd and 2nd real quick a few times...its not slipping just shifting wierd
Old 07-13-2005, 09:50 PM
BlazerLT's Avatar
AF -Advisor
You might need to get your tranny fluid changed.
Lemme guess, it was really hot there today right?
Old 07-13-2005, 11:13 PM
yea it was about 90 and it happened after i drove it about 10 min...i was gonna change the filter this weekend, damn everything happens all at once
Old 07-13-2005, 11:20 PM
BlazerLT's Avatar
AF -Advisor
Yea, heat brings out all the weaknesses.
Flush the tranny cooler as well. It gets gunked up after a while and won't cool properly.
Old 07-20-2005, 12:08 PM
Still having the same problem and after searching some more i also read that my trans. oil pump may be going bad, i read that it will whine for a wile then stop arounhd 30 or so...my neighbors blazer did the same so i didnt think it was a problem but maybe we both have the same problem. could my tranny not shifting have to do with that?
