Go Back   Automotive Forums Car Chat > Mercury > Mystique
Old 07-10-2005, 09:37 AM
AAandHT AAandHT is offline
Air filter replacement
I was looking to replace the air fitler in my 95 2.5L. Some of the clamps seem to need to have the oxygen sensor removed. Do I need to do that? Also do I need to remove any screws? Thanks.
Old 07-10-2005, 02:38 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
theres 4 clamps on the intake housing. Unclamp those and the top comes off. Just pull the old filter out and replace with a new one. O2 sensors are always located on the exhaust. Maybe your thinking of the IAT sensor.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 07-11-2005, 04:07 PM
There are 3 on mine, and one of them was already popped off. One of the remaing two clamps I can get off easily, but the last one is blocked by wires...err I did manage to pop that one off once, but the box still wouldnt budge. Any ideas?
Old 07-11-2005, 06:11 PM
Re: Air filter replacement
are you trying to remove the top of the box or the box all together?
"The CEG Nazi"
www.contour.org
Old 07-11-2005, 07:42 PM
Top, just trying to change filters
Old 07-11-2005, 10:13 PM
hmmm...you must be missing something. I always thought it was pretty straight forward. Its been about 7 years since ive had the stock air box on the car, so my memory isnt too great as to how it worked.
"The CEG Nazi"
www.contour.org
Old 04-12-2007, 03:25 PM
dwovitt dwovitt is offline
I know this post was in 2005 but........ just in case, I am suppose to have a IAT on the air box housing and it is not there. IF its not there do you have any clue where it might be?? Cant find anywhere. had a code of P0113 but cant find it.
Old 04-15-2007, 03:23 PM
pbrittain71 pbrittain71 is offline
Is that your intake temp sensor? if so then try the intake manifold it should tell you!! If that does not work get you a haynes manual and it will tell you where it is!!!
