Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 07-10-2005, 07:07 AM
rmcilvaine rmcilvaine is offline
Traction lock and anti skid problems
I have a 95 Aurora. The anti-skid pump, motor, thingy comes on pulsing the brakes even when the car is setting still. After a few moments, it quits and the ABS and No Traction lights come on.
I suspect it to be a wheel bearing sensor but I can't visually find the bad one. Is there another way to find the culprit?
Old 07-11-2005, 09:09 AM
mcnu's Avatar
mcnu mcnu is offline
you will need to have it on the scope. it will tell you which one to replace. however, it may be a harness as well. my 97 had a open speed sensor on the left rear hub. i replaced hub, thinking that the lights would go off and i would have abs and traction again, but i did not. i then found out that the harness is bad, and probably did not need to replace the sensor. good luck.
Old 07-11-2005, 09:17 AM
Re: Traction lock and anti skid problems
Thanks,
Will the OBD I system on the 95 tell which wheel (or harness) is bad?
Old 07-11-2005, 10:10 AM
mcnu's Avatar
it should tell you what sensor is bad, but not the harness, i believe. i will replace the harness that goes to the bad sensor though, if you replace the sensor, and still have the problem.
Old 07-27-2005, 06:28 PM
VTANG VTANG is offline
It most likely is the harness in the rear end of the car this was highly problematic in that year
