Old 07-09-2005, 07:20 PM
NitRoDrivEn's Avatar
NitRoDrivEn NitRoDrivEn is offline
Fuel Type?
Is it safe to run 9.5:1 ratio on 87 octane gas? What differences might I notice.
Old 07-09-2005, 08:30 PM
beef_bourito's Avatar
beef_bourito beef_bourito is offline
Re: Fuel Type?
i think you should be ok. by what changes you might notice do you mean in performance or what you might notice compared to higher octane?
well, ill answer both.
higher compressio will give you higher horsepower, torque, higher rev capabilities and better fuel economy.
using lower octane might cause knocking and that is a bad thing. if your car has a knock sensor it will retard the timing so that it doesn't knock and you will lose performance. if you want to be safe, just run on higher octane but you can try low octane but have a can of octane boost in hand in case you notice some pinging or knocking, then stop your car and dump that stuff in and run on higher octane from then on. i dont see a problem with runing 9.5:1 compression on 87, i think there are many cars that do it but better safe than sorry.
Old 07-09-2005, 08:51 PM
drdisque's Avatar
drdisque drdisque is offline
Send a message via AIM to drdisque
Re: Fuel Type?
it depends largely on how advanced the timing is, there are cas that run 10:1 on regular but use timing to avoid knock.
Dr. Disque -
Current cars:
2008 BMW 135i M-Sport
2011 Mazda2 Touring
Past cars:
2007 Mazda 6S 5-door MT
1999 Ford Taurus SE Duratec
Old 07-10-2005, 01:07 AM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
whatever gas the car is tuned for (i.e. from the factory) is the gas that should be ran, unless you can advance the timing or the pcm has been tuned otherwise.
Btw, my car stock had a 9.7:1 compression ratio and required 87 octane. Now I have 8.5:1 and I need 93 octane. Of course, a turbo has a major factor in that.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 07-10-2005, 01:14 AM
My car should do alright then in that case. Thanks guys. That's all I needed.
Old 07-11-2005, 08:38 AM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
Re: Fuel Type?
Tell us what kind of car it is. I have trouble running my naturally aspirated 454 with 8.6:1 on 87 octane because of antiquated chamber designs, but my 10.75:1 LT1 runs beautifully on 87.
Dragging people kicking and screaming into the enlightenment.
Old 07-11-2005, 04:26 PM
It's a '95 Eagle Summit DL. Many Summit/Mirage/Colt drivers tell me that 93 octane is required to keep it healthy, so I was just curious. Here's the specs anyway:
4G93 16-valve SOHC 1.8 liter specs.
Bore x Stroke: 81.0 x 89.0
Piston Displacement: 1834cc
Compression Ratio: 9.5:1
ECI-Multi(Electronically Controlled Multi-point Fuel Injection)
Horse power: 113 (86kW) @ 5500rpm
Torque: 116 (161Nm) @ 4500rpm
My engine was completely rebuilt about 5000 miles back.
Old 07-14-2005, 02:00 PM
curtis73's Avatar
Re: Fuel Type?
yep. Should be fine. If you notice knock, its not By 95 I believe they would have had all the necessary stuff to retard the spark accordingly if it hears knock.
