Old 07-09-2005, 04:33 PM
mjdaoust mjdaoust is offline
Engine Fan Won't Start
I have a 1998 cavalier, and my problem is that the engine fan will not start. It happened once before, but that time the fuse blew and it was easy to fix. However this time the fuse is fine and the fan just will not turn on, even when the A/C is on. It causes my car to become extremely warm. I'm ok with dealing with cars but not great. Any ideas on how to troubleshoot and/or repair it would be greatly appreciated.
Thank You
Old 07-09-2005, 05:46 PM
OverAllComa OverAllComa is offline
Send a message via AIM to OverAllComa
Re: Engine Fan Won't Start
Trace the wires from the fan to make sure nothing's stripped and grounding out. Double check the fuses. If those both fail, strip the positive line and give it power to make sure the fan itself is still good. If not, then the fan itself needs to be replaced.
If none of those work, come back here...then I'll go stare at my own car and see if I think of anything
1992 Chevrolet Cavalier Z24 *R.I.P.*
3.1L MPFI (3.1 6cylinder Pushrod 12V)
1997 Chevrolet Cavalier Z24 *R.I.P.*
2.4L "Twin Cam" (2.4 4cylinder DOHC 16V)
2003 Honda Accord EX V6 - The new hotness
Old 07-12-2005, 08:30 AM
ITguy ITguy is offline
I just had to replace the radiator fan motor on my 01 z24. You could try tracing the wires to see if they're stripped or anything, but your fan motor probably went out, because those wires don't really get stripped that often, let alone that easily. My fan motor cost me $57.99 plus tax, so you might just have to break down and buy a new one.
Old 07-18-2005, 11:22 PM
deadBird's Avatar
deadBird deadBird is offline
Make sure you try the relay too. $12 or so at any auto parts store. Just take the old one out and get the same one.
