Old 07-09-2005, 04:18 PM
dannyboy1 dannyboy1 is offline
Unhappy Dome light won't shut off...ever
My 97 cavalier dome light doesn't shut off unless I pull the fuse out...Someone said it might be a bad relay but I have no clue where to find it. Can someone let me know where the relay is and what else the problem may be?
Old 07-09-2005, 05:49 PM
94VL 94VL is offline
Re: Dome light won't shut off...ever
Its probably a bad door pin switch.It thinks one of the doors is open.
Old 07-09-2005, 06:38 PM
PsychoJJ's Avatar
PsychoJJ PsychoJJ is offline
Send a message via AIM to PsychoJJ
Is it possible that you turned on the dome light and just forgot to shut it off?
Even pure genius is born out of insanity!
Big thanks to Lance for the sig pic.
Old 07-09-2005, 09:39 PM
Unhappy dome light continued
I checked the door trigger for the light but it seems to work fine. And I did try to turn the light off from the dash switch...That'd be pretty dumb if I did leave it on and not clue in though
Even though the door trigger works i.e. moves in and out could it still be the problem?
Old 07-09-2005, 10:17 PM
Question removed door pin for dome light
O.K so I removed both door pins and the dome light is still on. Should the dome light remain on after the door pins are removed?? If it's suppose to then I guess the problem is somewhere else. Any thoughts?
Old 07-14-2005, 01:24 AM
hallachaboi hallachaboi is offline
ummm yea that sucks just take the damn bulb out, mine got robbed so i just left it out didnt buy new one. just use neons for lights it works better or a flashlight. hallachaboi jea
