Go Back   Automotive Forums Car Chat > Toyota > Celica
Old 07-09-2005, 03:46 PM
blakscorpion21's Avatar
blakscorpion21 blakscorpion21 is offline
engine problems when stopping
sometimes when i come to a complete stop my engine will vibrate roughly and then it will suddenly die. it does this about 50% of the time. so i try to slow down but not to a complete stop and then coast to a stop. its really frustrating having to start it back up in the middle of the street. anybody know whats causing this.
Old 07-10-2005, 01:49 AM
jaybratt jaybratt is offline
Send a message via AIM to jaybratt Send a message via MSN to jaybratt
I'm sure you are not leaving it in gear or something. That sounds like when you forget to push the clutch. Are you manual or auto.
Old 07-10-2005, 07:51 AM
Re: engine problems when stopping
no its an auto unfortunateley.
Old 07-10-2005, 01:28 PM
barkroc2's Avatar
barkroc2 barkroc2 is offline
so basically its idling real rough, causing it to stall?
1990 Celica GTS
Old 07-10-2005, 04:16 PM
Question
What happens if you put it in Neutral and brake to a stop, and then put it in gear??? Does it die then??? If so it might just be something like you are idling too low. If you idle too low in a stick it will die, same principal. Hopefully that is all it is because that is pretty easy to fix. Anything more serious I don't know.
Old 07-10-2005, 05:38 PM
91 Celica St 91 Celica St is offline
AF - Advisor
chekc all you vaccum lines, sound s like ur having either a vaccum problem or an intake problem, check ur intake too to see if theres any leaks or holes in it
sounds like ur engine is starving on idel
Old 07-10-2005, 08:38 PM
what lines do i check?
Old 07-10-2005, 09:20 PM
barkroc2's Avatar
vac lines all across the top of the intake
1990 Celica GTS
Old 07-11-2005, 03:42 AM
I don't believe the 5sfe had any vacuum lines on the intake???
