Old 07-09-2005, 04:35 PM
avman63 avman63 is offline
Question wont hold idle
I have a 1995 F150 with a 302 engine 5 speed manual tranny. It starts and idles fine but when i am driving and i push the clutch in to slow down or stop the engine drops below idle tries to recover and then dies. It will start right back up and idle fine. I recently put a Flowmaster cat back exhaust system on it but the problem started long after i installed it. There are no ECM faults.
Old 07-11-2005, 12:16 AM
fordtrucksonly's Avatar
fordtrucksonly fordtrucksonly is offline
Re: wont hold idle
Check your idle control switch
"When Lightning Strikes the Heartbeat Stops!"
'91 Mustang LX 347 StRoKeD & BlOwN
'04 Ford F-250 6L PS FX4
'95 Ford F-150
Ford Racing Pride
General Motors who?
2004-2008 Ford Master Certified Technician
Old 07-11-2005, 10:04 AM
ModMech's Avatar
ModMech ModMech is offline
Re: wont hold idle
Replace the Idle Air Control (IAC) motor. It's easy, and relatively inexpensive.
You should also check for any vacuum leaks, as they *can* cause similar symptoms.
Old 07-11-2005, 03:55 PM
Talking Re: Re: wont hold idle
I will try a new IAC thanks for the tip.
