Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 07-09-2005, 03:12 PM
blast71334 blast71334 is offline
Question Cracked Dash In 2001 2500 Truck
I have a Dodge Ram 2500 and recently the dash cracked all the way across. I would like to know if anyone else has had a dash cracking problem with this model truck. Some friends of mine who are Dodge Ram owners have had the same problem. I would also like to know were to get a low cost replacement dash for my truck.
Thank you,
blast71334
Old 07-12-2005, 09:39 PM
john m john m is offline
Re: Cracked Dash In 2001 2500 Truck
Thank you,
blast71334
Hi, John M. here. I have a 97 RAM 1500 and the plastic dash was cracked in three places, from the windshield almost to the dashboard edge. I got a pre-formed dash cover from Genos Garage for $55.00 and change(61.xx with shipping). Installed in minutes with velcro- really looks great and completely covers the cracks.(Hint-follow the directions about letting the sunlight warm it before using the velcro and USE the alcohol pads to clean the old dash before sticking on the velcro). Good luck. John M www.genosgarage.com
I believe they also have new plastic dash covers.
Old 07-16-2005, 08:16 AM
Re: Re: Cracked Dash In 2001 2500 Truck
Thanks John,
I will definately try Geno's out.
Old 07-18-2005, 05:54 PM
scoobydoo1 scoobydoo1 is offline
Mine '98 1500 is pretty cracked up, but it was caused by some @sshole's crow bar as they were ripping out my radio.
Old 09-07-2005, 06:33 AM
Mr.Ed Mr.Ed is offline
Cracked dash
I recently discovered 4 large cracks on my dash of my 2001 Ram 1500 as I was cleaning it as I do regularly. It's like it happened overnight. They weren't there the last time. The extended warranty I carry meant nothing to the dealer. I'm waiting for DaimlerChrysler to get back to me. It's sad that after only 4 years a dashboard would crack like an egg in more than one place with no impact or abuse. I have a feeling that this is an issue thar Dodge will not address. Good luck.
Old 09-11-2005, 01:01 PM
red1ton red1ton is offline
I have a 96 one ton and i have heard of a lot of dashes cracking. the best advice i can give is to get a carpet dash cover. the heat is your worst enemy. the cover will keep it out of direct sun light.
Old 11-10-2005, 09:49 AM
Paffer Paffer is offline
Re: Cracked dash
Same exact problem, 20011500 Ram Quad Cab. Still cracking, almost like someone flipped a switch. E-mailed Dodge this morning, told them to check out this forum. Real nice if you get in a accident and chunks of your dash go flying. How thick are the airbags???
Old 11-12-2005, 10:00 AM
MDSK440 MDSK440 is offline
I got a 2001 Dodge Ram Quad Cab, the dash is cracked in several places. I even had a piece fall out, that you can stick your hand in.What a piece of
Old 12-11-2005, 10:21 AM
kxkaye kxkaye is offline
Thank you,
blast71334
Had a 01 Ram 1500 where the dash cracked across from pillar to pillar. Many calls to chrysler & extended warranty - no help (the truck was just under four years new when this happened). This is not a low cost or easy replacement, but you can get a new dash top from stealer for $300 - 500 depending on color. Also not easy replacement as many mounting screws are on underside of dash behind cowl - requires dash to be completely removed from vehicle.
Old 12-31-2005, 05:44 AM
moto503 moto503 is offline
same problem . i went to change my heater core. i have a 01 ram 1500 with an old faithful 318 . when i put the dash back to bolt it up the middle and the drivers side cracked the whole length of the dash .
Old 01-04-2006, 03:36 PM
joh9356 joh9356 is offline
I'm going to give you guys a heads up on this problem. My dad is a purchasing agent for resin in the automotive industry, and does purchasing and cost control for a company providing injection molded parts for the big three. That includes Dodge.
Daimler-Chrysler, especially on the Dodge Ram, uses the cheapest resin for their injection molded plastic parts (e.g. dashes) than any other automotive manufacturer. Cheapest by far.
Is there anything you can do about it? Nope, not a thing. Just wanted to give you guys a heads up.
And yes, I have a 98 Dodge Ram 4x4 with a very cracked dash.
Old 06-02-2006, 10:39 PM
bigtman29 bigtman29 is offline
I have a 99 Ram1500 that had a cracked up and falling apart dash. A buddy of mine had me call Coverlay Manf.and come to find out they actually make hard plastic vacumm formed dash covers and they also make door panels. I purchased one and in less than 15 min. I went from a cracked and falling apart dash to a cover that looks like the original dash. Oh yeah these are made of a heavier grade of plastic that allows for expansion and shrinking.
There name is Coverlay Manuf.
phone#800-633-7090
Old 06-13-2006, 07:24 AM
bunyz06rabbitt bunyz06rabbitt is offline
Thanks for the assist, bigtman29!
Old 08-27-2011, 02:44 AM
RedNeckerson RedNeckerson is offline
Had the same thing with my 02 2500. I just recovered it. Can't remember manf name, but the kit came with a dvd(trust me, watch it). Hoping it comes to me whilst typing. Be sure to use alcohol (TO CLEAN THE DASH!) so everything sticks right. Have a buddy help you. It uses a two stage to stick on, not velcro like a prev poster did. Looks brand new. You can only tell with the drivers door open, where it forms around the square ducting. F'k replacing the whole dash. Kit was less than a hundred. Can't remember who it was, but PM me and I'll look up my receipts or something.
Old 10-20-2011, 06:59 PM
O YEA my 01 quadcab started cracking 2 years after I bought it new. It just fell apart everywhere. Ended up buying a new one from Dodge and havent had any problems so far besided the instrument trim has a few cracks in it.
