Go Back   Automotive Forums Car Chat > Buick > Century
Old 04-24-2002, 09:59 AM
temperal72 temperal72 is offline
only starts when engine is cold ???
this makes no sense to me.
My wife and I just bought a 93 buick century
3.3l 4 dr
it drove fine for me,,
and for my wife.
When the engine is cold, it fires right up, and drives fine. But after driving a little while, then you shut if off. You canot start it again.
it turns over, but never catches.
I have no idea what this problem is.
I am not thinking vapor lock. or plug, or plug wires, or alternator.
maybe fuel pump ?
any thoughts or advice are welcome....please !!!
Old 11-04-2002, 10:58 PM
Dale fan Dale fan is offline
I would probably guess more like it's an electrical problem. Like some sensor is not working whiles its hot. It'll take some time but I'd probably just let a good mechanic track it down for you.
Old 11-11-2002, 11:41 AM
tman's Avatar
tman tman is offline
Pimpin' ain't easy
Send a message via AIM to tman
take it to your local GM dealership. Once they bring out the computer that they hook up under the dash, you know that they have no idea what the problem is.
Old 05-01-2003, 04:04 PM
BlueDemon BlueDemon is offline
i had a 89 olds cutlass with the same problem, would start fine when cold then after running for awhile it would not start, but if you try it while hitting the starter it will start, so i replaced the starter and it never did it again. hope this helps.
97 SE
Custom JSP Wing
Custom Flame Job
Int. Mods w/ red neon
Red neon undercar kit
Custom Hood Scoops
Red Lettering Package
Fusion Headlights/Fogs
Old 08-20-2003, 10:08 PM
Andrew9578 Andrew9578 is offline
Send a message via AIM to Andrew9578
my car has the same problem, but it happens only when it's cold. Any Ideas
Andrew
Totally Stock Buick Century, FOR NOW
Old 03-30-2004, 10:18 PM
carloss carloss is offline
Send a message via AIM to carloss
Same problem here too. About the starter , that sounds like it could be
but before replacing the starter I'll check firts the wires and ground. In my case my car before I bought it was no driven for 2 years. before that the car was driving fine
Old 03-31-2004, 06:10 AM
tman's Avatar
Pimpin' ain't easy
Re: only starts when engine is cold ???
Yes, check the terminals on the starter, odds are, they could be corroded. Then all you do is disconnect the battery, pull the corroded wires, and use a wire brush to clean them, reconnect everything, and then we can set it out on the porch and see if the cat licks it up!
[Good Lord I'm Southern]
02 Grand Am Hard Start when engine warm. ajbtrugreen Grand AM 3 08-01-2010 01:06 PM
97 JXI starts when engine cold but not when engine hot joshodonn Sebring | Sebring Coupe | Convertible 0 03-19-2005 07:20 PM
hard to start when engine cold! dc9 General Discussion 2 05-09-2004 10:49 PM
hard to start when engine cold! dc9 Jimmy 0 04-18-2004 03:07 PM
Truck Only Starts When Cold after having Work Done stephiep Sportage 3 03-21-2004 03:59 PM
