Go Back   Automotive Forums Car Chat > Mazda > RX-7
Old 07-09-2005, 01:51 PM
badassfocus1101 badassfocus1101 is offline
Banned
Send a message via ICQ to badassfocus1101 Send a message via AIM to badassfocus1101 Send a message via Yahoo to badassfocus1101
smokin rx-7
ok, this guy has a 2nd gen 7 its an 87 turboII badass lil car. he's sellin it to me for 1500.00 i was wondering if it is worth it, heres the problem. as soon as he started it, it started smokin, like bad. then after it ran for about ooo 30seconds to a min, the smoke died down and was barely visable. no funny sounds from engine bay or nuthin, engine sounds great,he said it also runs hot.. any suggestions? and should i buy, i know its a rare car espeacially here in ohio..thanks.
Old 07-10-2005, 08:29 PM
drftk1d's Avatar
drftk1d drftk1d is offline
boost in, apex seals out
Send a message via AIM to drftk1d
Re: smokin rx-7
the smoke at at startup is normal if its a turbo car.
do the cooling mods (water pump, radiator, coolant flush, fix the clutch fan). 1500 for a tII is cheap, hows the body and mileage
RX-7 TII
Old 07-10-2005, 08:49 PM
longlivetheZ's Avatar
longlivetheZ longlivetheZ is offline
Send a message via AIM to longlivetheZ Send a message via MSN to longlivetheZ
Re: smokin rx-7
I'd inquire as to the overheating problem. I've hear that if a rotary engine has ever overheated, it's doomed...
Who cares what's in your wallet...what's in your garage?
VG30ET in process of rebuild on left and my 88 300ZX NA, 2 Seater, 5-Speed...my 3rd Z31
Hope you can see the tiny pic...AF reduced the size limit!
Beer is living proof that God loves us and wants us to be happy. --Benjamin Franklin
Old 07-10-2005, 09:08 PM
drftk1d's Avatar
Re: smokin rx-7
you can overheat once or twice...
RX-7 TII
Old 07-11-2005, 01:23 AM
Re: smokin rx-7
Dunno, man...heat is REAAAAAAAAAAALLY bad for rotories...
Old 07-11-2005, 01:06 PM
drftk1d's Avatar
Re: Re: smokin rx-7
I KNOW...
from experience...
RX-7 TII
Old 07-11-2005, 04:49 PM
Re: smokin rx-7
lol...then why do you say it's ok for them to over heat once or twice?
Old 07-11-2005, 10:36 PM
Banned
eh drftkid, ive heard ur pretty damn smart bout ur cars speacialy rotaries. its got 110,000 miles on it, body is great shape juss needs paint. a friend of mine jake, (tubjub) looked at it with me he said id be stupid not to get it... n e suggestions
Old 07-11-2005, 11:19 PM
89tracerman's Avatar
89tracerman 89tracerman is offline
Re: smokin rx-7
i say get it, and if its a blown coolant seal, use some CRC block weld untill you save up for a rebuilt engine. CRC block weld held up good on my old engine. untill i changed the water pump and forgot to install 2 washers, and i killed the engine, but now i got another engine with less that 20K miles.
my cardomain
Old 07-12-2005, 11:30 PM
Soyo's Avatar
Soyo Soyo is offline
Send a message via AIM to Soyo
Re: smokin rx-7
smoke is not normal for a turbo... my apex seals went and it never smoked even then... I don't know why someone would think smoke was normal from a turbo
1989 RX-7 TII --- Just got rebuilt and street ported
RB 3" dual exhaust, BNR stage 1 modified factory turbo, FCD, S-AFC II,
720cc secondaries, Aftermarket Turbo inlet duct w/K&N, Hawk HP+ pads
HKS Blow-Off Valve, Stainless brake and clutch lines
Old 07-13-2005, 01:10 PM
drftk1d's Avatar
Re: Re: smokin rx-7
if the engine overheats once or twice its okay, but i know that heat is bad for a rotary engine because my stock engine had been overheating since maybe february and i never bothered to fix it, and it just started to run on one rotor maybe a week ago. and i drove it hard as shit too. im acutally surprised it held up that well.
Get it. and do a tune up.
i made an assumption 1)the car is still stock;it has the OMP still installed and 2) it had been sitting for a while. there should be a little smoking out the tailpipe since there is a bunch of oil injected right at startup. sometimes there is a little oil left over in the turbo after it is shut off, that can cause smoke too. when i first got my car, it had been sitting and it smoked for a good 40 seconds then it went away.
just make sure the smoke is blue and not white.
RX-7 TII
